Anyone else found the new ProSYS Plus software to be flaky, badly designed and laid out to make it as complicated as possible to program without a laptop?
The BUS system in particular is really bad, personally I have only second fixed and commissioned these systems. System 1 was cabled in CAT5e (apparently recommended by Risco tech)? had to double up power cores to get voltage above 10v at the keypad. System 2 was cabled in alarm cable and I had to double up on the power cores again and run two separate data lines within the same cable splitting the detectors up from the keypads … it was the last resort and only thing that worked. however, 3 keypads on the system but only 2 show up. if 3 show up then nothing works. Metered the cable, fine, cable length less than 50m (estimated as I did not first fix) appears to be no interference. Every time I did a BUS device re-learn it changed what it saw for the keypads. conclusion.. bad cable or bad software. personally I think flaky software, would love to hear your thoughts/experiences.
Paul
Paul
You have the software?
risco tat...
31 minutes ago, Xilant Security said:
Dial up configuration software ... yes
Via laptop?
5 hours ago, Xilant Security said:
Yes via laptop , remotely and direct link
Ok so what's issue then? Only hard for those who don't have all that
That leaves you with flakey software , personally I only offer to rip it out , is this your usual meaning risky ?or risco whatever you call it
40 minutes ago, Xilant Security said:
Flakey software ... I usually use Orisec these days, it’s great stuff. Only play with Risco when I sub to others that use it..
Orisec getting better yeah?
