vinnychoff Posted August 3, 2018 Posted August 3, 2018 Hi look forward to your help and suggestions. I have installed three systems and am moving to a new house with a double garage attached. I have a old galaxy panel and am happy with its service to date. I am thinking of buying a Flex 20 panel and prefer wired sensors. This is the list that I am thinking of buying. 6 x - Honeywell Flush Magnetic Contact - White 6 x - Honeywell Galaxy ASK Keyprox Proximity FOB 2 x - Honeywell Plastic PA Button 2 x - Honeywell Indoor Siren Grade 2 2 x - Honeywell IS3016 PIR Motion Sensor 16 X 22m 2 x - Honeywell Reson8 Bell Box 3 x - Honeywell Optical Smoke Detector ECO1003-A 3 x - Honeywell 12v non latching detector base 2 x - Honeywell PIR Night Vision 10m IB 1 x - Honeywell Galaxy Flex 20 UK Large Panel & MK8 Keypad 1 x - Honeywell Galaxy Flex 20 UK Panel & MK8 Keyprox with Internet 3 x - Honeywell Viper GLX SENSOR WHITE GRADE 3 1 x - CQR SC555/AL/4CX Patio Door Contact 1 x - SECWARE H10A Aluminium Angle Contact I found all this on security warehouse. I have thought to alarm the garage with the up over door on a contact and install a pir with camera. Is this the best way? I was going to put three smoke alarms in kitchen, garage and room under the garage. I am thinking of adding cameras but from a different system. Is it more effective to use Honeywell products? Not sure of solutions? Looking at the flex 20 panel I have the following zones. I think its only 12 wired so will have daisy chain the doors upstairs? That is how I managed my doors present and this worked ok. Is ver1 software better than ver3?? On the security warehouse site it costs a few pounds more for ver1 which seems strange? I would like to be able to disarm the system as i drive in and open the garage door. I assume that on the internet app i can do this? I also have a motorcycle but guess its best to dismount, switch the system off and then park up the motorcycle. Any suggestions on this? The house is on two levels with a room under the garage also. zones 1 front door 2 hall pir 3 garage pir with camera, garage door contact. Has two small windows?? not sure what to do maybe just stop from being opened? 4 Room under garage (man cave) door contact, smoke alarm and break sensor. Single door and window 5 patio doors break sensor, patio contact. back of house. 6 back door contact and break sensor. 7 dinning room pir 8 lounge pir 9 bedroom 1 door contact 10 bedroom 2 door contact 11 bedroom 3 door contact 12 bedroom 4 door contact 13 bathroom door contact 14 windows downstairs contacts. probably not going to put any. 15 break sensors zone? link all three. 16 panic buttons bedroom. 1 panel 2 key panels? Should i install one in the garage? 4 pir,s 7 door contacts? 1 patio doors contact window contacts ? 2 panic buttons 3 break sensors 2 internal sounder 2 bell box 3 smoke sensors to the alarm 1 garage door contact? Thanks in advance? Vince Quote
sixwheeledbeast Posted August 3, 2018 Posted August 3, 2018 Far too many question marks to work out where your questions are, but I'll try and help answer... On 03/08/2018 at 11:27, vinnychoff said: I have thought to alarm the garage with the up over door on a contact and install a pir with camera. Is this the best way? Expand I would say Shutter contact and DT. On 03/08/2018 at 11:27, vinnychoff said: I would like to be able to disarm the system as i drive in and open the garage door. I assume that on the internet app i can do this? I also have a motorcycle but guess its best to dismount, switch the system off and then park up the motorcycle. Any suggestions on this? Expand I don't fit Honeywell controls as standard. I'd use a Texecom external prox reader for this type of thing. Tag on your garage keys, swipe the tag, open the garage and park up, could do similar on the way out too with correct programming. I don't really rate apps myself. When it comes to your bike is it the right solution? Think about having to pull up, find your phone in your leathers, take your gloves off, find the app, disarm, put your phone back etc.. On 03/08/2018 at 11:27, vinnychoff said: I am thinking of adding cameras but from a different system. Expand I would say separate system would be better for redundancy On 03/08/2018 at 11:27, vinnychoff said: 2 internal sounder 2 bell box Expand This sounds like far too much kit for one panels PSU. On 03/08/2018 at 11:27, vinnychoff said: This is the list that I am thinking of buying. Expand Are you definitely looking to DIY? This seems a large project for a your standard DIYer, lots to learn and trip up on along the way. 1 Quote
vinnychoff Posted August 3, 2018 Author Posted August 3, 2018 Sixwheeledbeast Thanks, I have fitted four alarms in friends and families houses. Those were scantronic panels and pirs etc but the same procedure. I have a background in mechanics and electrical work so feel confident with a meter and settings. Some panels like the scantronic can have one extra sounder and i thought it is not too hard to power two but can reduce to one. I have not added a garage though so not sure and the other parts. I could add a prox tag with the Galaxy panel and install outside? the same as your Texecom external prox reader? Quote
sixwheeledbeast Posted August 3, 2018 Posted August 3, 2018 On 03/08/2018 at 12:45, vinnychoff said: panels like the scantronic can have one extra sounder Expand I would argue they can't without the sounders being low current types. It doesn't matter how many outputs a control panel has, the supply can only provide a certain load (this isn't just sounders this is the whole system BTW). A panel could run overloaded for a while before it gives up prematurely. On 03/08/2018 at 12:45, vinnychoff said: I could add a prox tag with the Galaxy panel and install outside? the same as your Texecom external prox reader? Expand Maybe see what other people suggest. Quote
Nova-Security Posted August 3, 2018 Posted August 3, 2018 Flex 20 with a RIO, as i counted up 18 zones on your list only gives you 2 spare though Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Nova-Security Posted August 3, 2018 Posted August 3, 2018 On 03/08/2018 at 12:45, vinnychoff said: I could add a prox tag with the Galaxy panel and install outside? the same as your Texecom external prox reader? Expand Get the galaxy app, then you will get push notifications as well as being to arm/disarm from your phone. BTW you will need an Ethernet module 1 Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
al-yeti Posted August 3, 2018 Posted August 3, 2018 On 03/08/2018 at 18:37, Nova-Security said: Get the galaxy app, then you will get push notifications as well as being to arm/disarm from your phone. BTW you will need an Ethernet module Expand And maybe some firmware Quote
Nova-Security Posted August 3, 2018 Posted August 3, 2018 On 03/08/2018 at 19:10, al-yeti said: And maybe some firmware Expand No problems on the flex Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
GalaxyGuy Posted August 3, 2018 Posted August 3, 2018 Agree. No issues with the Flex V3.50 firmware. Set for silent comm's to ensure no panel side error reports for broadband issues. Not everyone likes the SMPS (including me), but energy efficiency is more important going forwards. Honeywell push notification is limited, but is free, so it's up to you. At least there are other choices with SelfMon if you want additional SMS, E-mail and hourly path checks. Quote
