Hi All
I've come across an issue at a site where its been fine for over a year and now im getting spurious alarm signals between 12am and 3 am from various long rang detectors. It started with just one detector so it was changed but now its multiple including the changed one.
Its a large builders merchant with a large warehouse, there isn't any sign of animal life. The only thing is the warehouse is rather hot and I wondered whether the cooling of the building would effect these particular detectors. The thing is now isn't as hot as it was so i'm a little stumped.
On 04/08/2018 at 19:08, scrimshanker said:
they are all mounted on the inside of the exterior metal cladding.
On 04/08/2018 at 17:35, The Arab said:
Are they mounted on a solid base or outer cladding ?
Likely the cladding is moving with heat expansion.
Microwave can only help minimise false alarms if device is fixed to a solid surface.
Normally I'd agree but it hasn't done it during the really hot spell in June!
Although it is far more humid now.
It has to be heat related, I was wondering whether anyone has had issues with these detectors before due to heat?
51 minutes ago, Nova-Security said:
are they going off or going high resistance
There's no sign of anything technical yet.....
HousebashersRus
