Hi all,
just a quick question for you and someone may have an answer.
when setting my customers 9651 in Mode B for when they go to Bed I have the exit mode set as silent set.  Now there is no problem setting it or anything it is just that when I walk past the hall detector to go upstairs, the keypad beeps and displays zone fault.  Is there anyway other than taking that detector off the system in B that can stop this beeping?  I need the detector as it is my entry route in the morning for the timer on the keypad to unset alarm.
Any help appreciated.
thanks
1 hour ago, NJK91 said:
There is no other attributes just set as FE abcd as there is no door contact.
This panel is mashed on this , especially earlier version, went over this with doctor fusion , he's missing in action now
On part set they set the alarm off when you enter that zone rather than starting the timer
Ideally best situation is to install a second keypad upstairs and unset from there
Although on silent set if it's in timer exit because mode B has an exit time
3 hours ago, sixwheeledbeast said:
From what I remember the best you can do is turn down the LS volume.
Front door contact is normally a good idea due to this type of thing.
Eh?????
