Pat Posted August 6, 2018 Posted August 6, 2018 Scantronic 9752 two keypads,had to remove K02,put panel into installer mode and disconnected K02 whilst still powered up unable to get out of installer mode panel indicates K02 missing, do I need to power down panel and restart to finally delete K02? Quote
al-yeti Posted August 6, 2018 Posted August 6, 2018 What happens if you press tick when it says it's missingĀ Quote
Pat Posted August 7, 2018 Author Posted August 7, 2018 Scantronic 9752 two keypads,had to remove K02,put panel into installer mode and disconnected K02 whilst still poweredļ»æĀ up unable to get out of installer modeļ»æĀ panel indicatļ»æes K02 missing, do I need to power doļ»æwn panel anļ»æd restart to finally delete K02?ļ»æļ»æļ»æļ»æļ»æļ»æļ»æļ»æļ»æļ»æļ»æ Quote
sixwheeledbeast Posted August 7, 2018 Posted August 7, 2018 Please don't repost the same question. Try a power cycle, yes. Quote
Amps Posted August 7, 2018 Posted August 7, 2018 Nobody seems to know Pat. If you find out please let us āprosā know how please. Quote
sixwheeledbeast Posted August 7, 2018 Posted August 7, 2018 I am sure pros would just have a crack at it Scannys are pretty basic, if desperate could default and reprogram in 15 minutes. It's normally recommended to down power controls before removing BUS devices. Quote
aissecur Posted August 7, 2018 Posted August 7, 2018 I would power down (mains & Battery) & then power back up & see if it is still missing the keypad address Quote
al-yeti Posted August 7, 2018 Posted August 7, 2018 1 hour ago, aissecur said: I would power down (mains & Battery) & then power back up & see if it is still missing the keypad address Yeah all pros would do this , I don't believe there is a remove device option for that you just lash it off and restart as above Quote
Pat Posted August 13, 2018 Author Posted August 13, 2018 Powered down panel added fresh battery powered up again no fault this time with K02 missing.Given the keypad was originally removed whilst still powered panel was still probably looking for KO2, resolved anyway thanks for help Quote
