PeterJames Posted August 8, 2018 Posted August 8, 2018 Not very green it makes you wonder whats going to happen to all that plastic Quote
sixwheeledbeast Posted August 8, 2018 Posted August 8, 2018 It's all relative. Continuing the car analogy... You could have a shiny new alarm for the cost of a dealer service. Also cars worth over 1k wouldn't likely be as old as this Accenta. Quote
Seb Posted August 8, 2018 Author Posted August 8, 2018 3 hours ago, sixwheeledbeast said: The service is because it's been a non-maintained system so checks would need to be done, part of this would be to diagnose the fault and get the system operational. Having a service and repair is more cost effective in the long run than someone resetting your PA for the cost of a call out. If your alarm system sounds when isolating the power it clearly shows the system hasn't been serviced in a good while and the battery will be dead. Expect an incoming approved company to recommend a panel upgrade and service contract too. Top info, for that! Hopefully resetting the PA will do it, failing that I'll have a look for an engineer to fix/replace it. Hopefully it won't cost too much! Cheers all, for the info :). Quote
al-yeti Posted August 9, 2018 Posted August 9, 2018 4 hours ago, Seb said: Top info, for that! Hopefully resetting the PA will do it, failing that I'll have a look for an engineer to fix/replace it. Hopefully it won't cost too much! Cheers all, for the info :). Hope PA button dont snap when you turn that key lol Quote
