I have a couple of Galaxy MK8 keypads and for some reason the key backlight is hardly visible
My other MK8 is bright but these 2, barely lit, is there some way to adjust it?
I see no controls on the PCB.
The screen backlight seems OK
Is it because your comparing to the mk8?
Not sure what you mean there
all 3 are MK8, 2 of them seem have very little in the way of backlight behind the keys
14 minutes ago, norman said:
Have you tried swapping the RKP's  to see if it's a voltage issue?
yea doesn't seem to be a voltage problem
Unlikely but just a thought, I've never had issues with them but the LED's are easily replaced if you are OK with a decent soldering iron.
Sorry thought two different
3 hours ago, Nova-Security said:
There is in the keypad programming
I see an option for the backlight for the screen on/off but not the keys brightness level
