Posted (edited)
I am trying to install Scantronic 9448+ control panel but i am facing a problem with my EE zone and Zone 3 as i set it for Entry Exit as well.
The alarm does not go off in the external sounder (Bell) for Entry Exit Zones, it only goes off in the Internal Sounder.
Is there a way to over come this problem.
Thank you.
Edited by Bradynew
1 hour ago, Bradynew said:
If I disable Dual Ply the external sounder will go of immediately after my Entry/Exit time for EE zones?
After the entry time expires it should go into alarm correct
Only Just seen this,
Are you part setting the system? If so you have a part set response on the programming menu (it can either be full alarm or internal sounder only)
