inglishg Posted August 26, 2018 Posted August 26, 2018 I've been asked to fit a sim dialler to a guys system and what I imagined to be simple hasn't turned out that way (very familiar to us all I suppose...). The guy has bought a sim dialler which apparently needs a positive remove from the trigger terminal to cause the unit to send out it's messages. However as said, he only has a very simple panel (optimal compact), and these are fixed as negative trigger... Is there a solution, or is it a change of dialler or panel? Cheers Quote
al-yeti Posted August 26, 2018 Posted August 26, 2018 Relay Or what is exact SIM dialler in question seems odd what your saying Quote
al-yeti Posted August 26, 2018 Posted August 26, 2018 1 minute ago, inglishg said: I've been asked to fit a sim dialler to a guys system and what I imagined to be simple hasn't turned out that way (very familiar to us all I suppose...). The guy has bought a sim dialler which apparently needs a positive remove from the trigger terminal to cause the unit to send out it's messages. However as said, he only has a very simple panel (optimal compact), and these are fixed as negative trigger... Is there a solution, or is it a change of dialler or panel? Cheers The bell output is normally high and drops when tirggered so it could be same as saying negative applied But if what your saying is a technical issue then it's weird as positive removed can mean it doesn't want to see ov either But probably basic SIM diallers are negative applied for trigger as many diallers and should work on the belloutput for trigger Try it perhaps hope you got plenty credit on the SIM Quote
james.wilson Posted August 26, 2018 Posted August 26, 2018 it is 12v pos removed Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
