jonnas Posted September 3, 2018 Posted September 3, 2018 Hi Guys I am having trouble with night setting my enforcer, am hoping someone can help ? I have 4 Pir sensors in total and 4 door contacts in total all programmed in A for the full set. I also programmed the 4 door contacts which are downstairs and 3 off the Pir sensors downstairs under B as well. When I full set the alarm under A the sensors downstairs did not activate the alarm when set, but the one pir upstairs did activate the alarm. When full setting the alarm when the house is empty do I need press A and B ? Not sure if I have made an error programming somewhere. Quote
