Tony Park Posted September 4, 2018 Posted September 4, 2018 Hi all, I've just joined the forum, in the hope I can get some help with our alarm control panel. I'm installing some one automation in our house, and trying to use our hardwired pirs as sensors for triggering events. I've installed 2 fibaro universal sensors in our alarm control panel. I installed the first unit which appears to have been OK, and working as expected. When I installed the second, we developed the strange issue. The battery is about 8 years old, and the control panel was already installed in our house when we bought it 9 years ago. I've replaced the battery, as it was getting rather warm in the box, and causing the transformer to get warm. I've also checked and replaced all the slow and fast fuses. So, the issue is that the vertical line of leds is not lighting at all. The keypad leds show fine,but the keypad does nothing when pressed. The led indicators on the pirs all work fine, turning on when detecting movement, and off again after a second or so, of no movement. I'm wondering if the pvb is dead. Would anyone have any other thoughts? Same happens whether on mains (no battery) or battery (no mains) Thanks, in advance Tony Quote
james.wilson Posted September 5, 2018 Posted September 5, 2018 if it was working before you connected things to it then id disconnect everything but the keypad and see how it is Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
aissecur Posted September 5, 2018 Posted September 5, 2018 I suspect you may of blown one of the panels quick blow (I would test them) Quote
al-yeti Posted September 5, 2018 Posted September 5, 2018 12 hours ago, Tony Park said: Hi all, I've just joined the forum, in the hope I can get some help with our alarm control panel. I'm installing some one automation in our house, and trying to use our hardwired pirs as sensors for triggering events. I've installed 2 fibaro universal sensors in our alarm control panel. I installed the first unit which appears to have been OK, and working as expected. When I installed the second, we developed the strange issue. The battery is about 8 years old, and the control panel was already installed in our house when we bought it 9 years ago. I've replaced the battery, as it was getting rather warm in the box, and causing the transformer to get warm. I've also checked and replaced all the slow and fast fuses. So, the issue is that the vertical line of leds is not lighting at all. The keypad leds show fine,but the keypad does nothing when pressed. The led indicators on the pirs all work fine, turning on when detecting movement, and off again after a second or so, of no movement. I'm wondering if the pvb is dead. Would anyone have any other thoughts? Same happens whether on mains (no battery) or battery (no mains) Thanks, in advance Tony Also think about scrapping it Quote
Tony Park Posted September 5, 2018 Author Posted September 5, 2018 1 hour ago, james.wilson said: if it was working before you connected things to it then id disconnect everything but the keypad and see how it is Hi, I've tried with the original setup, and still seems to be the same situation. Looks like a new pcb... any idea where to get the same one nice and cheap? Thanks Tony Quote
al-yeti Posted September 5, 2018 Posted September 5, 2018 4 hours ago, Tony Park said: Hi, I've tried with the original setup, and still seems to be the same situation. Looks like a new pcb... any idea where to get the same one nice and cheap? Thanks Tony eBay ? https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/security-control-panels-c-36_102/control-panels-all-c-36_102_41/scantronic-9448eur90-p-172.html Quote
magpye Posted September 6, 2018 Posted September 6, 2018 (edited) POST DELETED Edited September 6, 2018 by magpye getting ahead of myself Quote Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
