Jdagnew Posted September 6, 2018 Posted September 6, 2018 Hi guys, I’ve just purchased the ricochet 64w with wireless keypad and can’t get it to register on the system. I have followed the instructions and repeated it several times but still no joy. I’m wondering if I have a faulty panel. I install the keypad batteries and quickly replace the back cover and plug in the cable before pressing yes to install the keypad. Yes I have the cable plugged into the engineers port, first thing I checked.It does a search but returns “No Ricochet Network Found“. The only thing I can think of is that I might need to have the backup panel battery fitted which I don’t have yet...it is ordered and should be here soon. Is there something I’m missing here? I know years ago in my old house I had a faulty panel out of the box so I know it can happen. Thanks. Quote
donut Posted September 6, 2018 Posted September 6, 2018 Does the wireless keypad have a DIP switch anything to do with that? Quote
Jdagnew Posted September 6, 2018 Author Posted September 6, 2018 4 hours ago, donut said: Does the wireless keypad have a DIP switch anything to do with that? Yes it does, I left it as default but also tried changing it but it didn’t help. Quote
donut Posted September 6, 2018 Posted September 6, 2018 (edited) have you had a look on this thread? Edited September 6, 2018 by donut Quote
Jdagnew Posted September 6, 2018 Author Posted September 6, 2018 42 minutes ago, donut said: have you had a look on this thread? Yes I did see this one but I couldn’t see anything that would help that I hadn’t already tried. I will try again over the weekend but I’m of the thought that I’m going to need to return the panel for a replacement. Quote
al-yeti Posted September 6, 2018 Posted September 6, 2018 3 hours ago, Jdagnew said: Yes I did see this one but I couldn’t see anything that would help that I hadn’t already tried. I will try again over the weekend but I’m of the thought that I’m going to need to return the panel for a replacement. You haven't hard wired yet though From default Quote
Jdagnew Posted September 7, 2018 Author Posted September 7, 2018 7 hours ago, al-yeti said: You haven't hard wired yet though From default I’m not sure what you mean by hard wired? I’m only using wireless on the whole system and I have used the engineer cable to connect from the key pad to the panel. From what I understand, this is the first step when setting up. Once the key pad is connected I can then proceed to learn all the other devices. If I’m missing something please let me know. Thanks. Quote
