donut Posted September 6, 2018 Posted September 6, 2018 (edited) I have installed the alarm and programed including adding a smartcom wifi. My question is, currently i have all my pirs assigned to one zone. If I want to part arm the system at night, thereby not having upstairs pirs active, how do i do this in programming . I am using wintex. Is it to do with ticking part emit 1 on those sensors? Edited September 6, 2018 by donut Quote
donut Posted September 6, 2018 Author Posted September 6, 2018 This probably answers my question 1 - PART 1 OMIT Zones with this attribute will be omitted when ‘Part Arm 1’ is selected. Zones without this attribute will respond as normal. 1 Quote
sixwheeledbeast Posted September 7, 2018 Posted September 7, 2018 Helps when you read the manual. Quote
donut Posted September 7, 2018 Author Posted September 7, 2018 3 hours ago, sixwheeledbeast said: Helps when you read the manual. Several times Quote
Jdagnew Posted September 8, 2018 Posted September 8, 2018 On 06/09/2018 at 13:30, donut said: I have installed the alarm and programed including adding a smartcom wifi. My question is, currently i have all my pirs assigned to one zone. If I want to part arm the system at night, thereby not having upstairs pirs active, how do i do this in programming . I am using wintex. Is it to do with ticking part emit 1 on those sensors? Although I’m having learning issues with my new wireless system, I have used Texecom for several years. You need to break your system into zones rather than omitting sensors. I have my downstairs/conservatory and garage on 1 zone and upstairs on another. We had a keypad upstairs so when we go to bed we “part” set the system which secures downstairs/conservatory and garage(pir’s and contacts) but leaves the 1st floor off so that we can move around/bathroom etc. Quote
sixwheeledbeast Posted September 8, 2018 Posted September 8, 2018 Zones, Areas and Part sets are all different things Quote
