stelmo Posted September 17, 2018 Posted September 17, 2018 Im sure there is an obvious answer to this but its baffled me Ive wired up a relay to zone 2 on a galaxy dimension and set the function to PA silent. when the relay opens all I get is 'System Fault' ive got a 1k resistor in series then a 1k across the relay, so it measures 2k when open and 1k when closed If I change the function of the zone to intruder, from pa silent then opening and closing the relay gives no error! bizarre... Quote
al-yeti Posted September 17, 2018 Posted September 17, 2018 18 minutes ago, stelmo said: Im sure there is an obvious answer to this but its baffled me Ive wired up a relay to zone 2 on a galaxy dimension and set the function to PA silent. when the relay opens all I get is 'System Fault' ive got a 1k resistor in series then a 1k across the relay, so it measures 2k when open and 1k when closed If I change the function of the zone to intruder, from pa silent then opening and closing the relay gives no error! bizarre... Thought that was normal , does it say on keypad system reset required once triggered ? I doubt it comes up with fault but then I just a house basher Quote
stelmo Posted September 17, 2018 Author Posted September 17, 2018 Definitely says 'System Fault, Reset Required' According to the manual it should result in 'no audible or visual indication of the activation' Quote
stelmo Posted September 17, 2018 Author Posted September 17, 2018 Im concluding that this is some sort of obfuscation of the event(Personal attack input), whilst also indicating that something needs dealing with? Ill go through the event logs, but ive come to the conclusion that this is by design, and not documented Quote
al-yeti Posted September 18, 2018 Posted September 18, 2018 (edited) 8 hours ago, stelmo said: Definitely says 'System Fault, Reset Required' According to the manual it should result in 'no audible or visual indication of the activation' Yes that's correct on dimension, I meant it couldn't come up with just fault as you mentioned, Perhaps changing it to 24hr? Custom Sia etc might solve the issue or customer zone and make links where appropriate or something to stop the message display James or nova or galaxy guy know better......they sleeping tho Edited September 18, 2018 by al-yeti Quote
