MaxX Posted October 20, 2018 Posted October 20, 2018 22 minutes ago, SeanT said: Yes you can, I used m2m (machine 2 machine) they ensure you sim will never expire Ah great thanks - I was looking at a global m2m sim too - may try the gifgaff first and see how well that works. Quote
MaxX Posted October 20, 2018 Posted October 20, 2018 13 minutes ago, SeanT said: ok, I think you need to go into engineers menu using * 0132 Then go into programming # Then system # then controls # the communications # Fm enable half unlock symbol (y/n) Cool thanks for that - I’ll try that later. I also want my cloud connection to use IP first / then GPRS if IP not available - I saw the setting for that in: Programming > Communication > Cloud Quote
SeanT Posted October 20, 2018 Author Posted October 20, 2018 5 minutes ago, MaxX said: Cool thanks for that - I’ll try that later. I also want my cloud connection to use IP first / then GPRS if IP not available - I saw the setting for that in: Programming > Communication > Cloud Can’t really comment on that as I don’t have my system set up like that but hope it works Quote
MaxX Posted October 23, 2018 Posted October 23, 2018 On 20/10/2018 at 20:15, SeanT said: Can’t really comment on that as I don’t have my system set up like that but hope it works Just put my SIM in today - added all the FM numbers - did an FM test from the user menu too, FM test basically called my mobile number.. I have a question about arming, I know the GSM is working as it is giving me a status message by text, however when I do an ARM or HOME ARM command: 1234 A OR 1234 H It does nothing, No message from panel - checked panel still showing Ready and I did "1234 ST" for status message - got SMS from GSM module that the system is Ready. Does your SMS arming work? Did you have to do anything else? Thanks Quote
SeanT Posted October 23, 2018 Author Posted October 23, 2018 I think you’re using the wrong commands to set and unset your alarm, you should be using S to set and US to unset so if your code is 1234 then you would use 1234 S to set and 1234 US to unset (I don’t think it’s case sensitive and you can omit the space if you want to). There is a list of commands in the user manual. Hope this help 1 Quote
MaxX Posted October 23, 2018 Posted October 23, 2018 (edited) 37 minutes ago, SeanT said: I think you’re using the wrong commands to set and unset your alarm, you should be using S to set and US to unset so if your code is 1234 then you would use 1234 S to set and 1234 US to unset (I don’t think it’s case sensitive and you can omit the space if you want to). There is a list of commands in the user manual. Hope this help That is awesome mate - just tried your commands and they work - S for SET and US for UNSET Do you know the command for Part Set - I assume 1234 PS? I am looking at my manual dated June 2013 which informs us to use A FOR ARM, H FOR PART ARM, D FOR DISARM....which is obviously incorrect... Do you know where I can get the latest User Manual from? Thanks Edited October 23, 2018 by MaxX Quote
SeanT Posted October 23, 2018 Author Posted October 23, 2018 Glad it worked, I think its just P for part set, have a look at the list below: I'll see if i can find a link to the update manual for you 1 Quote
MaxX Posted October 23, 2018 Posted October 23, 2018 Many thanks - appreciate your help with this! Quote
SeanT Posted October 23, 2018 Author Posted October 23, 2018 (edited) There are various versions of the user manual that have slightly different commands, such as A and H for arming and disarming (as you found out). The manual I have uploaded is as close to my original paper copy as I could find, however, it is slightly different but for most things it should be ok. Risco_Agility_User_Manual.pdf Heres a link I found that matches my manual dated 2012, the previous one is 2009: https://irp-cdn.multiscreensite.com/a1d869e9/files/uploaded/Agility-2-Full-User-Manual-UK1.pdf Edited October 23, 2018 by SeanT 1 Quote
MaxX Posted September 26, 2019 Posted September 26, 2019 Hello guys, I have a Risco Agility 3 with IP and GSM - both comms working fine. I have defined two Follow Me (FM), 1 = Me via SMS and 2 = The Wife via SMS also. I as FM1 get all SMS for events defined no probs. However, FM2 (i.e. The wifes phone) does not get anything - her phone is defined correctly - FM test successful (she gets a text) and she can set/unset via sms no probs. Is this by design perhaps, that the system tries the FM numbers in order and if FM1 IS successful, i.e. a SMS was sent ok to FM1 THEN IT IGNORES ALL OTHER DEFINED FMs? If so then it's a bit silly, as we would both like to get SMS for all events defined. Any thought and ideas will be appreciated. Quote
