Guest miketubby
Guys,
After being told by several people that my Galaxy 500 PCB with 2.31 n it couldn't be upgraded, I went out and acquired a new Galaxy 500 PCB with version 4.39 installed.
As I'm the curious sort, I decided to compare the PCBs, other than the date codes they both look identical and have part/revision code ZP1-0077-2.0 with the mod-level 0 slashed through
So, I pulled the 4.39 chip out of the new PCB and stuck it in the old one and fired her up <_< ... after about 20 seconds of beeping and flasing of the line of stars I finally got the "Configuring Please Wait" and then it dropped to "Alarm In Progress" :huh: So, I logged in and its full of tampers and O/C's for zones which we're programmed as spares (I was lazy and didn't put 1Ks on those zones), and the date and time had reset to Sun 01 Jan.
Other than that, it works just fine... so... why did I "need a new PCB" exactly? Looks like the only change is the EPROM <_<
So, I'm off to work in a bit to duplicate that version 4.39 EPROM and put it in my *spare* PCB ... hmmm... now I've got to Galaxy 500's with 4.39 in them :!:
Mike
Posted (edited)
the problems start when outputs sometimes fail to trigger,thats why you need the new pcb,
Edited by eng
Guest miketubby
31105[/snapback]
Yeah, but... new PCB??? I've checked... they're identical in all respects... layout, components fitted, revision numbers, etc. The 'speacil' chips which are the Programmable Array Logic (PALs) for "address decode" and "RS485 decode" are the same versions also...
Okay, some of the capacitors are physically different, i.e. different manufacturer, but same value... other than that there's nothing, zip, nada, nil... between the old and the new board.
I would be suprised if I had any problems as you suggest.
I sugest that I have a Jul 2002 boatd with 2.31 (//.National Installer.//) and an Aug 2004 board with 4.29 (generic) in it, but they are the *same* hardware.
The EPROM is an STM (ST Microelectronics) 27C4001 ... I'll dig one out at work tomorrow and program it up with the 4.39 code... I'll bet you a beer that it "just works" .
In the mean time, who's got a copy of the firmware 5.04 (or later) for the Telecom Module that they'll lend me to experiment with?
Mike
BTW I use a Dataman S4 hand-held EPROM programmer... support British industry... if you need a chip programmer go to Dataman - they're good kit! Dataman Programmers
if you put diesel in a petrol car it will just work for a short time,but will work,that doesnt mean its right...ive had loads of problems with new versions of software not being compatable with old versions
Guest miketubby
31138[/snapback]
Well, each to their own I guess... I had a PM from Allso, he says he's got a Customer Advice PDF from Honeywell/Ademco that confirms my experiance... Galaxy 500 hardware from 1.5 on wards can run any version up to/including 4.39
Mike
Posted (edited)
"BTW I use a Dataman S4 hand-held EPROM programmer... support British industry... if you need a chip programmer go to Dataman - they're good kit! Dataman Programmers" -
- bloody hell - just checked your link -at that price I hope it would be "good kit"
Edited by DNS Security
Guest miketubby
31154[/snapback]
Well, I think they're good value for money in-so-much-as its allowed me to fix problems on our vehicle tracking and mobile data systems in police/fire/ambulances with upgrades etc... no more than the cost of a couple of call-outs...
Mike
Mike
31153[/snapback]
not sure if thats strictly true,but after reading allso's posts he isnt qualified to comment on this subject,no offence intended..tho im sure ive got some updates from microtech somewhere i'll try to dig them out...but i do know that 2.31,4.04,4.10 4.36 had problems not sure which of these were //.National Installer.// only versions,not had a play with 4.39+ yet whats the diff from 4.37??
