Sirenblinky Posted October 13, 2018 Posted October 13, 2018 Hi. I am updating my alarm system to a Pyronics enforcer wireless wifi enabled setup. I have the wireless bell module paired to the system but want to wire in my Honeywell AG6 bell to the panel. Can someone help with wiring detail's? I have set up the panel with no problems and the App works fine for me currently testing it on my bench before final installation. Thanks Quote
al-yeti Posted October 13, 2018 Posted October 13, 2018 (edited) 2 hours ago, Sirenblinky said: Hi. I am updating my alarm system to a Pyronics enforcer wireless wifi enabled setup. I have the wireless bell module paired to the system but want to wire in my Honeywell AG6 bell to the panel. Can someone help with wiring detail's? I have set up the panel with no problems and the App works fine for me currently testing it on my bench before final installation. Thanks Do you have the wired module in the panel? The ag6 is no good for this panel as it doesn't have scb mode from what I remember , pack it send it back and get a texecom odyssey 1e or something like that After thought if you have a WiFi module installed can you still install the wired bell module? As I thought there was only a position for one board , or is the WiFi onboard the V10 main board? Someone else might answer that bit Edited October 13, 2018 by al-yeti Quote
grantc Posted October 13, 2018 Posted October 13, 2018 2 boards on them. Bell wired off the small PCB at bottom. Wire tamper across on of the onboard zones and program accordingly. Quote
Sirenblinky Posted October 13, 2018 Author Posted October 13, 2018 Thanks for the replies. Their is a board in the panel to wire an external bell so will the ag6 be suitable as I think it's a sab box. If so do I just wire it up to the panel and do I need to program and output. Quote
al-yeti Posted October 13, 2018 Posted October 13, 2018 (edited) 2 hours ago, Sirenblinky said: Thanks for the replies. Their is a board in the panel to wire an external bell so will the ag6 be suitable as I think it's a sab box. If so do I just wire it up to the panel and do I need to program and output. Sab box is no good for these small panels , on power cut, for any reason they can't give the hold off voltage required so you will get continuous bell rings etc Edited October 13, 2018 by al-yeti Quote
Sirenblinky Posted October 14, 2018 Author Posted October 14, 2018 Ok thanks looks like I will need an SCB box and a ladder then! Quote
