Sirenblinky Posted October 16, 2018 Posted October 16, 2018 Hi so I got the Deltabell and tried to wire it to the Enforcer panel. The problem I have is that when I arm the panel the Deltabell goes off! Please would someone advise me how to wire it including where the jumpers should be. I've set the jumper to SCB mode not sure about the rest. Thanks Quote
al-yeti Posted October 16, 2018 Posted October 16, 2018 27 minutes ago, Sirenblinky said: Hi so I got the Deltabell and tried to wire it to the Enforcer panel. The problem I have is that when I arm the panel the Deltabell goes off! Please would someone advise me how to wire it including where the jumpers should be. I've set the jumper to SCB mode not sure about the rest. Thanks Can you send pictures how your wired it or drawing or aomething Quote
Sirenblinky Posted October 16, 2018 Author Posted October 16, 2018 I tried to upload a photo but the file is to big so : deltabell: from the top terminal white_T resistor_T eng hold_ none stb_yellow bell_green 12v_red negative_black also resistor into this terminal linked in to 2nd T above Enforcer panel Red_12v+ Black_common Green_bell Stb_yellow White_D1 No links or resistors in panel Frustrating grrr Thanks Quote
Sirenblinky Posted October 16, 2018 Author Posted October 16, 2018 3 hours ago, Sirenblinky said: I tried to upload a photo but the file is to big so : deltabell: from the top terminal white_T resistor_T eng hold_ none stb_yellow bell_green 12v_red negative_black also resistor into this terminal linked in to 2nd T above Enforcer panel Red_12v+ Black_common Green_bell Stb_yellow White_D1 No links or resistors in panel Frustrating grrr Thanks Quote
al-yeti Posted October 17, 2018 Posted October 17, 2018 4 hours ago, Sirenblinky said: Here are some pics Why is resistor there? Just put a striaght link in Quote
al-yeti Posted October 17, 2018 Posted October 17, 2018 (edited) Also I think your white wire needs to go to z33 and z33 is programmable in menu as a bell tamper , z33 normally has the resistor on it in series so like white wire connects to resistor and then resistor goes into z33 , resistor mostly goes in bell , but your in bench DIY unit won't matter Been a while since I did this , isn't D- , zero volts so that's where the black would go ? Edited October 17, 2018 by al-yeti Quote
al-yeti Posted October 17, 2018 Posted October 17, 2018 D- to 0v D+ to 12v STB to STB Bell to bell Z33 to T Then leave resistor as you have it, you have a 4k7 there which needs to be also programmed in wiring selection choice menu Quote
Sirenblinky Posted October 17, 2018 Author Posted October 17, 2018 Excellent help guys will try again this morning thanks Quote
Sirenblinky Posted October 17, 2018 Author Posted October 17, 2018 I think the resistor I have in the pics is a 2k2 according to its colour bands. Quote
