techfreak Posted October 25, 2018 Posted October 25, 2018 Hi all I have an Accenta 6 system, as pictured, works fine but when the alarm goes off - for example when walking in the house or walking downstairs in the morning it's extremely loud. So loud i've had neighbours at the bottom of the street ask me where that sound is coming from! I've looked in the big box and there's a volume control button in there but turning it does nothing - sound stays the same. I've turned it every which way. Am I missing something? Thank you Quote
james.wilson Posted October 25, 2018 Posted October 25, 2018 you could put a resistor in series on the speaker. I assume its the entry exit tones? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
FASTCAR Posted October 25, 2018 Posted October 25, 2018 You could try removing the connection to the speaker , and just use the keypad tones...but you will loose high volume alerts and alarms. Quote
sixwheeledbeast Posted October 25, 2018 Posted October 25, 2018 Some numpty wired a sound bomb in the speaker terminals? Found that one a few times. Loudspeakers are generally not too loud. It could also be the alarm is programmed incorrectly and is full alarming on entry, the volume pot will do nothing for that. Quote
al-yeti Posted October 25, 2018 Posted October 25, 2018 14 minutes ago, sixwheeledbeast said: Some numpty wired a sound bomb in the speaker terminals? Found that one a few times. Loudspeakers are generally not too loud. It could also be the alarm is programmed incorrectly and is full alarming on entry, the volume pot will do nothing for that. As swb it's going into full alarm in part set Or your full setting at night with no sensor upstairs anyway and triggering full alarm Quote
techfreak Posted November 5, 2018 Author Posted November 5, 2018 On 25/10/2018 at 22:30, sixwheeledbeast said: Some numpty wired a sound bomb in the speaker terminals? Found that one a few times. Loudspeakers are generally not too loud. It could also be the alarm is programmed incorrectly and is full alarming on entry, the volume pot will do nothing for that. Thanks for the replies everyone. SWB - this sounds exactly like what's happening. It's not the entry or exit tones - that changes with the volume control but it's the full alarm that's triggering. Any way to fix this ? Quote
al-yeti Posted November 5, 2018 Posted November 5, 2018 2 hours ago, techfreak said: Thanks for the replies everyone. SWB - this sounds exactly like what's happening. It's not the entry or exit tones - that changes with the volume control but it's the full alarm that's triggering. Any way to fix this ? So you must have a PIR in hallway which needs it's setting changed, do you have engineer access? Quote
techfreak Posted November 5, 2018 Author Posted November 5, 2018 No idea? So I’m guessing probably not? I did read something about checking the pulse count setting on the PIR and setting this to 3? Would that help? Quote
al-yeti Posted November 6, 2018 Posted November 6, 2018 8 hours ago, techfreak said: No idea? So I’m guessing probably not? I did read something about checking the pulse count setting on the PIR and setting this to 3? Would that help? No The sensor that is activating needs programming correctly as swb has mentioned so that it starts the timer , It's better in this case you get an engineer to do it for you , it will be worth it and he can check the alarm for you same time connections battery charging and so on Quote
techfreak Posted November 8, 2018 Author Posted November 8, 2018 Hi Yeti You're right. I'll get a pro in to sort it. Cheers Quote
