paul44 Posted October 28, 2018 Posted October 28, 2018 Hi, do theses panels have built in speech diallers to alert the customer directly, or do you need a external dialler. Ive never worked on them before so not sure. Quote
al-yeti Posted October 28, 2018 Posted October 28, 2018 On 28/10/2018 at 11:05, paul44 said: Hi, do theses panels have built in speech diallers to alert the customer directly, or do you need a external dialler. Ive never worked on them before so not sure. Expand External dialler required , coms device onboard won't work for you unless you connected to an arc You could opt for selfmon if you want something in-between search online Quote
paul44 Posted October 28, 2018 Author Posted October 28, 2018 Cheers for the quick response al-yeti Quote
