al-yeti Posted November 10, 2018 Posted November 10, 2018 7 minutes ago, little_john said: J4 can be selected as G3 / G2 ?, and J8 will set to ext, i cannot test it again until monday, just want to say thanks for your input with this. Can't remember now about that jumper , but if it solves problem then select g2 if it doesn't then put the resistor in correct place Quote
little_john Posted November 10, 2018 Author Posted November 10, 2018 15 minutes ago, al-yeti said: Can't remember now about that jumper , but if it solves problem then select g2 if it doesn't then put the resistor in correct place Quote
