andiesstuck Posted November 10, 2018 Posted November 10, 2018 I changed a battery in the dining room PIR and the alarm now won’t set.Displays says:!!Enter Code!!!!!Check!!!I enter code and hit reset and the internal alarm starts sounding and display again says!!Enter Code!!!!!Check!!!I enter code again and it saysDining Rm RPI T!I’ve searched online (I know nothing about alarms) and I’ve tried stretching the spring slightly but still the same. I’ve tried attempting to set whilst holding spring down and get the same error.Please does anyone have any other suggestions? Quote
al-yeti Posted November 10, 2018 Posted November 10, 2018 6 hours ago, andiesstuck said: I changed a battery in the dining room PIR and the alarm now won’t set.Displays says:!!Enter Code!!!!!Check!!!I enter code and hit reset and the internal alarm starts sounding and display again says!!Enter Code!!!!!Check!!!I enter code again and it saysDining Rm RPI T!I’ve searched online (I know nothing about alarms) and I’ve tried stretching the spring slightly but still the same. I’ve tried attempting to set whilst holding spring down and get the same error.Please does anyone have any other suggestions? Do you have any other codes? You probably need an engineer reset , so you need to call someone anyway now Quote
PeterJames Posted November 11, 2018 Posted November 11, 2018 Tamper dining room, either the lid is off the detector or the cable is damaged,it wont clear until you have fixed the fault Quote
Amps Posted November 12, 2018 Posted November 12, 2018 There was a discussion on a Facebook security group about tampers being engineer reset on grade 2 systems. The standards say grade 2 tampers are user rest but some were saying they programme tampers for engineer reset as they do not like the end user to interfere with the control panel. Quote
aissecur Posted November 12, 2018 Posted November 12, 2018 I would check that tamper spring clicks when the cover is fitted and that the cover is seated correctly, then wait a couple of minutes then trigger the detector (so it sends a new signal to the panel) then type your code in. Is it possible that the system has been set up for engineer reset on tamper. If the above fails then you will have to make a call to the installing company / current maintainer Quote
MrHappy Posted November 12, 2018 Posted November 12, 2018 You really need to be an alarm engineer to change the batteries in risco radio alarm... Quote Mr Veritas God
al-yeti Posted November 12, 2018 Posted November 12, 2018 34 minutes ago, MrHappy said: You really need to be an alarm engineer to change the batteries in risco radio alarm... Proper Quote
MrHappy Posted November 12, 2018 Posted November 12, 2018 2 hours ago, al-yeti said: Proper Its quirky, you need product knowledge to clear "faults" Quote Mr Veritas God
al-yeti Posted November 13, 2018 Posted November 13, 2018 2 hours ago, MrHappy said: Its quirky, you need product knowledge to clear "faults" Yep Hi Honeywell wireless can be buggy to , amount of restarts needed sometimes before something clears , bugged panels hanging around texe maybe Quote
