31 minutes ago, sixwheeledbeast said:
All the SAB modules I used in the past where dipped, surprised to see one without.
Looks like a thin sprayed coating
I recal recall aritech ones filled with resin
Dragon ? with thin coating & ADE one with a even thiner coating
Google images have very few pic of bell mods
  • 6 months later...
On 21/11/2018 at 19:47, Gabs said:
The idea was just for a microswitch to go straight to to SCB of my Accenta panel, I could route it through my SAB module, but it would just be two tracks, from one terminal block to another. Could be done with standard 6 core wire, too.
2 for the Tamper
2 for the Hold Off voltage
2 for the Siren
I think it would be 2 for hold off and the other two for tamp return and trigger, usually an SCB module would use the bell box battery to run the bell and a SAB module uses a trigger voltage to power the bell.
