Posted (edited)
Hi All,
Hoping someone is familiar with the Honeywell Galaxy Flex 20 System?
Ive purchased one to fit at the new house as its something I have had an interest in..... However, I might have bitten off more than I can chew!
I have 3 different wiring instructions from the panel instructions, PIR instructions and general alarm fitting guide. Im trying to validate I have the correct PIR wiring method before wiring up the 10 PIR's! The PIR's are DT8012F5's with 6 terminals.
From what I can work out the PIR's should be wired as the image I have drawn. Can someone just confirm before I spend the day wiring them up wrong! :)
Edited by RevolvingSteve
  On 22/11/2018 at 19:08, RevolvingSteve said:
Ok, so take the brown core for example into NC and pair it into 0v with the yellow at the board?
Expand
Yes , not familiar with flex 20 but don't they have a seperate zero volts aux power ?
Your diagram is fine. There's only one common 0v on the galaxy, as per all Galaxy, so your link in the detector is fine. Detectors these days are very low current, so there is seldom any need to double up power cores.
Expand
Many thanks GalaxyGuy for the confirmation, appreciate your time, sure it won't be the last question! :)
  • 2 weeks later...
