DIY-Man Posted November 25, 2018 Posted November 25, 2018 (edited) Hello I had 2x low battery warnings on my Risco LightSYS 2 system with 6x wireless PIRs. They have lasted 4 years, so I changed the batteries in all sensors this afternoon. Single CR123A in each one. 4x are showing OK on the panel. However, 2x are still showing tamper, so the alarm cannot be set. They do pass the walk test though. After putting the cover back on I can clearly hear the tamper switch being set again. The panel warns about a PIR being tampered with when the cover is removed and you enter the user code to stop the panel beeping. I still have the "hammer" icon on the control panel (to indicate the tamper alarm). There is nothing in the user manual to help me clearing the tamper status for the remaining 2 sensors. Any ideas? Edited November 25, 2018 by DIY-Man Quote
MrHappy Posted November 25, 2018 Posted November 25, 2018 54 minutes ago, DIY-Man said: I still have the "hammer" icon on the control panel (to indicate the tamper alarm). they're not very nice to work with, either leave it to shut down & walk back into the rm & when it transmits it will clear the tamper, or view the signal strength in an eng menu or delete the tx & put it back on they get unstable with age Quote Mr Veritas God
DIY-Man Posted November 25, 2018 Author Posted November 25, 2018 (edited) You were right. If I visit each PIR they eventually seem to clear, and the tamper status goes away. All good now. Like you say, not very user friendly. On the plus side, I've gotten over 4 years battery life out of them. Edited November 25, 2018 by DIY-Man Quote
MrHappy Posted November 25, 2018 Posted November 25, 2018 1 hour ago, DIY-Man said: On the plus side, I've gotten over 4 years battery life out of them. sooner or latter the control will go tits up... Quote Mr Veritas God
DIY-Man Posted November 26, 2018 Author Posted November 26, 2018 What system would you recommend to replace it with, when it eventually fails? Must support wireless PIR. Preferably connection to a phone over WIFI for configuration and event viewing, etc. Risco has never really impressed me. Quote
MrHappy Posted November 26, 2018 Posted November 26, 2018 2 hours ago, DIY-Man said: What system would you recommend to replace it with, when it eventually fails? One of mine on fully inclusive servicing contract Quote Mr Veritas God
Saffron warrior Posted January 21, 2022 Posted January 21, 2022 On 25/11/2018 at 19:34, DIY-Man said: You were right. If I visit each PIR they eventually seem to clear, and the tamper status goes away. All good now. Like you say, not very user friendly. On the plus side, I've gotten over 4 years battery life out of them. Hi. I have the same problem now. I don't quite understand how you resolved it thanks Quote
PeterJames Posted January 22, 2022 Posted January 22, 2022 23 hours ago, Saffron warrior said: Hi. I have the same problem now. I don't quite understand how you resolved it thanks If you have changed the batteries already and closed the lid on the detector correctly. Come out of the room and leave it for 5 mins then go back in let the detector see you if that doesnt work call the installer.(Which is what you should have done in the first place) 1 Quote
james.wilson Posted January 23, 2022 Posted January 23, 2022 8 hours ago, PeterJames said: If you have changed the batteries already and closed the lid on the detector correctly. Come out of the room and leave it for 5 mins then go back in let the detector see you if that doesnt work call the installer.(Which is what you should have done in the first place) Qfa Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
