Hi. I programmed an extra pir sensor today and I may of altered the program on my pyronix enforcer w.e. Everything is working fine however when I enter engineering mode the hard wired siren goes off. Any ideas what I've done?
How have you wired the siren? Any message displayed in log?
Siren is wired worked perfectly before adding the pir. If I enter the engineer code the siren will sound then when I scroll down to log what am I looking for wording wise
Can't be perfect if since you added PIR it's mashed up
20 hours ago, al-yeti said:
DIY trigger
Ok all sorted now output not set correctly the bell should be set to siren any and bell any.
The bell output was set to engineer test or something like that.
Now working as it should
Thank you all.
Thank you all.
Hardcore Mr blinky you read the banter correctly
