Norzbeck Posted December 16, 2018 Author Posted December 16, 2018 20 hours ago, al-yeti said: You done anything I said then? Or ignored what anyone is writing? Hi Global Moderator, Thank you for your answer.I was really just wondering if I could do a straight swap using the existing 4,wires.Is that possible. ai-yeti, If you read my questions it was not to test the panel or anything else.I simply asked what I could exchange my non working bell too. Quote
al-yeti Posted December 16, 2018 Posted December 16, 2018 5 minutes ago, Norzbeck said: Hi Global Moderator, Thank you for your answer.I was really just wondering if I could do a straight swap using the existing 4,wires.Is that possible. ai-yeti, If you read my questions it was not to test the panel or anything else.I simply asked what I could exchange my non working bell too. Ok so choose a bell and yes you can Theoretically you only need the red and black if that's what's its doing to power the horn on trigger Tamper is another circuit which can be modified yes But any bell could work Photos? Quote
sixwheeledbeast Posted December 16, 2018 Posted December 16, 2018 1 hour ago, Norzbeck said: If you read my questions it was not to test the panel or anything else.I simply asked what I could exchange my non working bell too. Point being, I think you need to look at the bigger picture. Quote
Norzbeck Posted December 17, 2018 Author Posted December 17, 2018 23 hours ago, al-yeti said: Photos Hi Al- Yeti, Thank you for your help. Quote
Norzbeck Posted December 17, 2018 Author Posted December 17, 2018 Hi sixwheeledbeast, Why do I need to look at the bigger picture, to just change the outside sounder. Al- Yeti has said I can use any external bell,as there are only 2, wires that power it. Quote
MrHappy Posted December 17, 2018 Posted December 17, 2018 9 hours ago, Norzbeck said: Why do I need to look at the bigger picture, to just change the outside sounder. You want a 12v bell 6" bell to fit inside your existing an alarm sounder ? I can source you one, you want my best price or you wanna make a bid... Quote Mr Veritas God
sixwheeledbeast Posted December 17, 2018 Posted December 17, 2018 39 minutes ago, MrHappy said: You want a 12v bell 6" bell to fit inside your existing an alarm sounder ? I can source you one, you want my best price or you wanna make a bid... More expensive than a half decent sounder from SW? Quote
MrHappy Posted December 17, 2018 Posted December 17, 2018 7 minutes ago, sixwheeledbeast said: More expensive than a half decent sounder from SW? More expensive than an expensive sounder from an expensive wholesaler... then I want add 40% to cover my cost, but I will do free carriage 1 Quote Mr Veritas God
al-yeti Posted December 17, 2018 Posted December 17, 2018 12 hours ago, Norzbeck said: Hi sixwheeledbeast, Why do I need to look at the bigger picture, to just change the outside sounder. Al- Yeti has said I can use any external bell,as there are only 2, wires that power it. He means overall what's best , and is correct However send a picture of your bell inside and out And your control panel inside and out Then our yellow friend can list a sounder with free post for you that should work Quote
AICSystems Posted December 17, 2018 Posted December 17, 2018 On 15/12/2018 at 11:17, Norzbeck said: Hi Sorry if I addressed you by the wrong name.Why would replacing the bell be a waste of time.The alarm works perfectly fine.It is just the external bell does not ring when the alarm is activated. It's an old out dated bell which isn't worth trying to fix. Just grab a new SAB you often find with these old parts once one part fails the rest is sure to follow Quote
