We have a compact sl and the keypad is playing up   using the same number for to long do need to either change the code or replace the panel
Is this easy to do ?
Do we need any codes to reset and change the input codes
It is over 14 years old.
Any help appreciated
Be a good idea to have it checked over if it's hasn't been looked at in years.
Battery and possibly PSU will be shot if it's never been serviced. Don't want it waking all the neighbours up at 3am.
You can change the user code yourself if you can enter the code to get into the menu.
