9 hours ago, MrHappy said:
you press the open padlock & its sets level b ?
Did I already ask if you are in IT ?
I assume rkp is in all area's & you have level setting selected ?
Padlock/I are configured to SET B
Unlock/II are configured to UNSET B
Setting works fine, un-setting does nothing, just flashes red.
Yes, I am in IT.
Posted (edited)
On 16/01/2019 at 13:15, Amps said:
Check ‘System Options’
Internet beers for this man!
Thank you very much @Amps - that was the fix! The panel was set to YES, switched to NO and all is well.
On 16/01/2019 at 16:06, grantc said:
Why are you using 2 buttons to unset b?
The unlock button should be setup for unset any
Was 'testing', just wanted to triple check the fob wasn't defective.
Edited by Vini
