Bruce P Posted January 5, 2019 Posted January 5, 2019 Hi All I am trying to get SSIAB certified and have run into a couple of items that Im not to sure about and Im hoping you lot can help me 1. When measuring the resistance on the pir / door contact is it just the non active measurement I need or is it the active, non active and tamper measurement ? 2 Battery calculations. I understand that I need to test the current drawn from the battery for both Quiescent and alarm condition to ensure its compliant . I install my fluke inline between the battery and the alarm and turn off the alarm ,How long do I need to measure the current for as it keeps going up and never seems to stop going up ? 3 When timing the exit . is it from the time you start the exit on the panel or the time the exit door shuts.I have set up all my jobs as the front door as entry/exit so none of them will secure until the door closes on exit ? 4.I have a document from SSIAB about minimum documentation the keep and supply to the customer . I have most of this but unsure of what a "System Users Handbook" is which apparently needs the following in it Name, address and telephone number of Installation/maintenance/repair company. Name and telephone number of the ARC (if applicable). System visits record log (for service/maintenance) Log of Operational Checks (record of circuit resistance readings/wireless signal strength, PSU voltage and current readings etc) Record of bell delay, entry/exit, bell cut off, confirmation window times etc where applicable Is this a specific handbook or just a document that has all the above information in it. 5 acceptance certificate . Would I get this when I am SSIAB registered. Im sure these are really stupid questions but I cant seem to understand what I need to do Thanks Bruce Quote
MrHappy Posted January 5, 2019 Posted January 5, 2019 1. Cable of each pair + Voltage of powered detector 2. Your doing this when the mains is removed ? 3. Your SDP will then be "final exit" 4. BSIA 5. Make something ? Quote Mr Veritas God
