Guest sts Posted November 13, 2004 Posted November 13, 2004 No matter if i wire and programme zones as CC or EOL and set the panel for the correct setup all zones still have faults when i exit engineer mode. Any help would be appreciated. Dave
housty Posted November 13, 2004 Posted November 13, 2004 Hi sts What sort of fault are you getting??? link out all the zones at the panel and see if the problem is still there. Houston Security Systems Ltd Intruder alarms CCTV Door entry Fire protection Networking SSAIB Approved
Guest sts Posted November 14, 2004 Posted November 14, 2004 housty, Sorted the zones now but OP 1 connected to ext. sounder and OP 2 connected to strobe but they dont seem to work in alarm condition or by test. Am i missing something in programming or just being a dummy?
Guest IM_Alarms Posted November 14, 2004 Posted November 14, 2004 why are you using the outputs to trigger the external sounder and strobe, when you have a proper sounder section to connect to that doesn't require programming
Paul Giles Posted November 15, 2004 Posted November 15, 2004 Probably is but hasnt fitted the link to the common from 0v. 9851 has relays not the conventional bell, str etc. Regards Paul PG Security Systems Somerset SSAIB Certificate of Merit Installers. www.pgsecurity.co.uk
Guest sts Posted November 15, 2004 Posted November 15, 2004 Hi Paul, Yep the Ov common link was fitted. Found fault which was a dry joint on the rear of the pcb for the NO connection. Changed this to NO2 and all fine. Now exchanged pcb and all is fine. Chaps
Paul Giles Posted November 15, 2004 Posted November 15, 2004 Nice one, Old PCB then? PG Security Systems Somerset SSAIB Certificate of Merit Installers. www.pgsecurity.co.uk
