Ramanoop Posted January 14, 2019 Posted January 14, 2019 Do you use quad detectors as a matter of course? I’ve seen some posts here saying that all reputable installers use quad detectors. But that doesn’t seem right - Texecom for example only sells one kit with quad detectors in it. The rest have ordinary pet friendly ones. wondering whether there is really a benefit Quote
james.wilson Posted January 14, 2019 Posted January 14, 2019 never use 'pet' sensors. Mostly use quads Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
PeterJames Posted January 14, 2019 Posted January 14, 2019 IMO quads are the better detector for domestic environments. I do use pet detectors, I have a pet myself and use the Bossch Blueline DT, never had a fa and the detectors see me when I walk around the areas that I allow my dog when the system is set. In my bedrooms I have quad detectors. We only use quads we wont use cheap detectors they are just not worth it to save £5 per detector. We use Optex RX 40 mostly (Optex only make detectors so they are good at it) or the HKC Quad if we are using ID wiring. Quote
sixwheeledbeast Posted January 15, 2019 Posted January 15, 2019 Use quads as a minimum here as well. Same as above Optex or Bosch Bluline on the rare occasion I have to use a pet sensor. Consider many pet sensors mask or desensitise an area this can make them slow to respond in some environments. I fit Texecom controls and I never buy kits, they package the minimum stuff up for DIYers but there is never a job they fit well on, even some of the smaller kits. I purchase specific tested products from different manufacturers for the applications they go in, otherwise you may as well buy a kit from B&Q would be easier to install too. Quote
KWCFC Posted January 15, 2019 Posted January 15, 2019 The wireless Pyronix pet sensors you have to do two backflips and a cartwheel for the bloody things to detect movement. Quote
petrolhead Posted February 1, 2019 Posted February 1, 2019 (edited) On 15/01/2019 at 19:10, KWCFC said: The wireless Pyronix pet sensors you have to do two backflips and a cartwheel for the bloody things to detect movement. Expand true, but if you cut the top bar off the pet mask they are a lot more sensitive but still tolerate pets. nothong comes close to the bosch for being sensitive while still disregarding pets though. Edited February 1, 2019 by petrolhead Quote
KWCFC Posted February 1, 2019 Posted February 1, 2019 On 01/02/2019 at 09:10, petrolhead said: true, but if you cut the top bar off the pet mask they are a lot more sensitive but still tolerate pets. nothong comes close to the bosch for being sensitive while still disregarding pets though. Expand Yeah I was actually told that by Pyronix tech support when I first fitted them and struggled to walk test. A bit of a **** design if you have to do that ain't it Quote
Amps Posted February 2, 2019 Posted February 2, 2019 On 15/01/2019 at 19:10, KWCFC said: The wireless Pyronix pet sensors you have to do two backflips and a cartwheel for the bloody things to detect movement. Expand They need to be installed at 2.1 meters rather than 2.4 meters for the standard pir’s. Quote
sixwheeledbeast Posted February 2, 2019 Posted February 2, 2019 Another benefit of the Bosch is flexible mounting height even in pet setting. Quote
