RevolvingSteve Posted January 30, 2019 Author Posted January 30, 2019 9 minutes ago, al-yeti said: Why you keep the cable stripped so short? Strip back more will be easier for you to manage Also generally yes , a&b correct , I haven't really used the flex but the Rio could be powered with single keypad and you could take an aux 12v from panel if it has one to Rio Few ways you can do it can't see pics that well In my defence, it is my first effort! But yes with hindsight, I should have stripped back twice as much cable!! It looks more of a mess as I have not yet done the tidy up, I'll do this once all is working. I'll try to find wiring for the RIO Quote
al-yeti Posted January 31, 2019 Posted January 31, 2019 2 hours ago, RevolvingSteve said: In my defence, it is my first effort! But yes with hindsight, I should have stripped back twice as much cable!! It looks more of a mess as I have not yet done the tidy up, I'll do this once all is working. I'll try to find wiring for the RIO Rio should be where you wired in the keypad ab Quote
MrHappy Posted January 31, 2019 Posted January 31, 2019 12 hours ago, RevolvingSteve said: OK, C072 RIO fitted next to the main panel. Couple of questions: 1) Zone wiring is different, no 12v on the Zone terminals ( 1, 0v, 2, 3, 0v, 4 etc), I presume the 12v is connected to one of the 12v outputs on the opposite side of the expansion modules? 2) I can't find a wiring diagram for connecting the RIO to the main panel - Looking at it it looks like the B & A terminals on the RIO, but not sure the other end the woods is nice & square... Quote Mr Veritas God
RevolvingSteve Posted January 31, 2019 Author Posted January 31, 2019 2 hours ago, MrHappy said: the woods is nice & square... What do you mean? 12 hours ago, al-yeti said: Rio should be where you wired in the keypad ab Presume its just wired with the standard alarm cable.. Quote
al-yeti Posted January 31, 2019 Posted January 31, 2019 3 minutes ago, RevolvingSteve said: What do you mean? Presume its just wired with the standard alarm cable.. Yes Quote
