RevolvingSteve Posted January 19, 2019 Author Posted January 19, 2019 1 hour ago, al-yeti said: Correct , with resistors in place Is it a door contact with no tamper ? Good bloke you can then also get an RF card later I believe and have wireless zones , unless you already have that Already have the RF card, see below! 19 minutes ago, al-yeti said: Sounds ok Great. All seems done but I now have a tamper on the RF PORTAL 105. I don't have any RF Detectors connected? Quote
al-yeti Posted January 19, 2019 Posted January 19, 2019 33 minutes ago, RevolvingSteve said: Already have the RF card, see below! Great. All seems done but I now have a tamper on the RF PORTAL 105. I don't have any RF Detectors connected? Did you fit the spring in the portal? Quote
GalaxyGuy Posted January 19, 2019 Posted January 19, 2019 In the flex you fit a jumper on the tamper header of the portal. There are a few unused jumpers on the existing headers if you don't have any spare. Quote
RevolvingSteve Posted January 20, 2019 Author Posted January 20, 2019 On 19/01/2019 at 20:47, GalaxyGuy said: In the flex you fit a jumper on the tamper header of the portal. There are a few unused jumpers on the existing headers if you don't have any spare. Could you elaborate? Im not at the house until tomorrow but will check it out. On 19/01/2019 at 18:28, al-yeti said: Did you fit the spring in the portal? Again, you'll have to elaborate a little... Quote
norman Posted January 20, 2019 Posted January 20, 2019 I love galaxy but that had to be the fugliest rkp available. Quote Nothing is foolproof to a sufficiently talented fool.
RevolvingSteve Posted January 20, 2019 Author Posted January 20, 2019 5 minutes ago, norman said: I love galaxy but that had to be the fugliest rkp available. You mean the panel or the install Its on a temp wall for now until the room is done Quote
norman Posted January 20, 2019 Posted January 20, 2019 No, I meant the actual design of it, it's hideous and looks like a school electronics project. Quote Nothing is foolproof to a sufficiently talented fool.
RevolvingSteve Posted January 21, 2019 Author Posted January 21, 2019 On 19/01/2019 at 20:47, GalaxyGuy said: In the flex you fit a jumper on the tamper header of the portal. There are a few unused jumpers on the existing headers if you don't have any spare. Thats the only wire I have connecting the RF to the board Quote
al-yeti Posted January 21, 2019 Posted January 21, 2019 1 hour ago, RevolvingSteve said: Thats the only wire I have connecting the RF to the board Because it's in main box fit jumper next to the top switch Quote
al-yeti Posted January 21, 2019 Posted January 21, 2019 On 19/01/2019 at 20:47, GalaxyGuy said: In the flex you fit a jumper on the tamper header of the portal. There are a few unused jumpers on the existing headers if you don't have any spare. As Mr galaxy said Quote
