RevolvingSteve Posted January 21, 2019 Author Posted January 21, 2019 5 hours ago, al-yeti said: As Mr galaxy said Sorry guys im still confused.... Can you draw it in crayon, as clearly that's my level! Quote
al-yeti Posted January 21, 2019 Posted January 21, 2019 6 minutes ago, RevolvingSteve said: Sorry guys im still confused.... Can you draw it in crayon, as clearly that's my level! Look at your picture Right hand vertical board at top there is a switch , next to it is a jumper with two small pins , use the jumper to short both pins this will close the tamper If the card was in its own box it would have a spring on the switch instead Quote
RevolvingSteve Posted January 21, 2019 Author Posted January 21, 2019 (edited) You mean this: Edited January 21, 2019 by RevolvingSteve Quote
al-yeti Posted January 21, 2019 Posted January 21, 2019 49 minutes ago, RevolvingSteve said: You mean this: Yes Quote
RevolvingSteve Posted January 21, 2019 Author Posted January 21, 2019 22 minutes ago, al-yeti said: Yes Roger! Ill check it in the morning and report back! Quote
al-yeti Posted January 21, 2019 Posted January 21, 2019 11 minutes ago, RevolvingSteve said: Roger! Ill check it in the morning and report back! Now? Lol Quote
RevolvingSteve Posted January 21, 2019 Author Posted January 21, 2019 Just now, al-yeti said: Now? Lol I cant, its at the new house, Im not there again until tomorrow Quote
RevolvingSteve Posted January 24, 2019 Author Posted January 24, 2019 Problem solved, fitted the jumper and all fine. Once again, thanks for the help! Quote
RevolvingSteve Posted January 30, 2019 Author Posted January 30, 2019 On 19/01/2019 at 15:09, al-yeti said: So buy an expander as you have a 20 zone panel I thought OK, C072 RIO fitted next to the main panel. Couple of questions: 1) Zone wiring is different, no 12v on the Zone terminals ( 1, 0v, 2, 3, 0v, 4 etc), I presume the 12v is connected to one of the 12v outputs on the opposite side of the expansion modules? 2) I can't find a wiring diagram for connecting the RIO to the main panel - Looking at it it looks like the B & A terminals on the RIO, but not sure the other end Quote
al-yeti Posted January 30, 2019 Posted January 30, 2019 29 minutes ago, RevolvingSteve said: OK, C072 RIO fitted next to the main panel. Couple of questions: 1) Zone wiring is different, no 12v on the Zone terminals ( 1, 0v, 2, 3, 0v, 4 etc), I presume the 12v is connected to one of the 12v outputs on the opposite side of the expansion modules? 2) I can't find a wiring diagram for connecting the RIO to the main panel - Looking at it it looks like the B & A terminals on the RIO, but not sure the other end Why you keep the cable stripped so short? Strip back more will be easier for you to manage Also generally yes , a&b correct , I haven't really used the flex but the Rio could be powered with single keypad and you could take an aux 12v from panel if it has one to Rio Few ways you can do it can't see pics that well Quote
