RevolvingSteve Posted January 21, 2019 Posted January 21, 2019 So after installing my first alarm ever at home last week, I went to our flat to check it over for a new Tennant coming in and the Texecom Alarm (Fitted in 2005 when flat was new) was beeping constantly (double beep every few seconds). Feeling confident from my recent alarm fiddlings I decided to open it up to take a look and see if there was anything obvious. Found that the battery was from 2005 so went to Screwfix assuming it had failed and fitted a new one (exact same spec). Still beeping. Upon inspection it seems to have blown the fuse to the Battery, but I've never seen fuses like this before. Pics below. Does anyone have a part code or what I should search for to buy? Quote
al-yeti Posted January 21, 2019 Posted January 21, 2019 1 minute ago, RevolvingSteve said: So after installing my first alarm ever at home last week, I went to our flat to check it over for a new Tennant coming in and the Texecom Alarm (Fitted in 2005 when flat was new) was beeping constantly (double beep every few seconds). Feeling confident from my recent alarm fiddlings I decided to open it up to take a look and see if there was anything obvious. Found that the battery was from 2005 so went to Screwfix assuming it had failed and fitted a new one (exact same spec). Still beeping. Upon inspection it seems to have blown the fuse to the Battery, but I've never seen fuses like this before. Pics below. Does anyone have a part code or what I should search for to buy? So 20mm glass fuse on eBay look at rating on silver colar Quote
RevolvingSteve Posted January 21, 2019 Author Posted January 21, 2019 (edited) 1 minute ago, al-yeti said: So 20mm glass fuse on eBay look at rating on silver colar Rating seems to say F1A250V, would that be it? What are the coloured bands? Edited January 21, 2019 by RevolvingSteve Quote
RevolvingSteve Posted January 21, 2019 Author Posted January 21, 2019 3 minutes ago, RevolvingSteve said: Rating seems to say F1A250V, would that be it? What are the coloured bands? For anyone reading this in months or years to come, found a great resource page which explains the bands: http://www.slimlab.net/mirror/fusecolours/fusecolours.htm Quote
RevolvingSteve Posted January 21, 2019 Author Posted January 21, 2019 18 minutes ago, al-yeti said: So 20mm glass fuse on eBay look at rating on silver colar Fuses ordered, many thanks al-yeti... AGAIN!! Ill let you know if it resolves the issue Quote
PeterJames Posted January 21, 2019 Posted January 21, 2019 Did you check that fuse with a multimeter? It doesnt look blown to me. Check the batteries in your smoke detectors for the beeping Quote
al-yeti Posted January 21, 2019 Posted January 21, 2019 5 minutes ago, PeterJames said: Did you check that fuse with a multimeter? It doesnt look blown to me. Check the batteries in your smoke detectors for the beeping This is DIY man we need fuses Quote
aissecur Posted January 23, 2019 Posted January 23, 2019 Worked on these redcot systems a couple of times before, they appear to always lock the nvm Quote
sixwheeledbeast Posted January 23, 2019 Posted January 23, 2019 Yep and went bust with not many people knowing the code IIRC. Quote
Nova-Security Posted January 24, 2019 Posted January 24, 2019 Worked on a few, and changed eng code Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
