Nath@Homesmart Posted January 23, 2019 Posted January 23, 2019 I am looking to extend the time count down on my security system after I set the alarm. Can anyone advise on the right settings I need to use or how I do it or if I can do it at all. Regards Nath Quote
al-yeti Posted January 23, 2019 Posted January 23, 2019 4 hours ago, Nath@Homesmart said: I am looking to extend the time count down on my security system after I set the alarm. Can anyone advise on the right settings I need to use or how I do it or if I can do it at all. Regards Nath You mean exit time not ally set by the engineer Do you have access to the engineer menu or have the engineer code? Although the the V2 Tel is a dialler I assume there is another box next to it? Or a picture of your keypad or it has a name on it Or are using the dialler as an alarm? Quote
sixwheeledbeast Posted January 23, 2019 Posted January 23, 2019 I suggest if you have not had the system looked over in a while to get someone to do a full service replace and batteries required and while there on site I am should they can change this to suit. Quote
Nath@Homesmart Posted February 12, 2019 Author Posted February 12, 2019 Thank you both. I don't have access to the engineer menu as we didn't have it installed for us, it was here when we moved in and not sure how it works if i am honest. I will probably be best to get someone to service it as it has been here before we had this building. Regards Nathan Quote
al-yeti Posted February 12, 2019 Posted February 12, 2019 2 hours ago, Nath@Homesmart said: Thank you both. I don't have access to the engineer menu as we didn't have it installed for us, it was here when we moved in and not sure how it works if i am honest. I will probably be best to get someone to service it as it has been here before we had this building. Regards Nathan There's probably another panel it's connected to or has been removed , so yes good idea to have it looked at Quote
Nath@Homesmart Posted February 13, 2019 Author Posted February 13, 2019 There is another panel that I can access but I don't know what I have to do when i go through the settings. Regards Nathan Quote
al-yeti Posted February 13, 2019 Posted February 13, 2019 2 hours ago, Nath@Homesmart said: There is another panel that I can access but I don't know what I have to do when i go through the settings. Regards Nathan In that case definitely get engineer it will be worth it Quote
