DSC power832
Guest jongary
Guest jongary
Hi, Does anybody know why this radio DSC power832 bleeps intermitently whilst unset. It could happen twice a night and then not do it for a week or so. The troulbe light indicates a fault but when you *2 i think all that comes up is general service required? I have tried to reset the system and clear the service timers etc.
Have alos read on the forum about power problems, can someone highlight me on this.
Regards
rgj
After the *2, I take it light 1 comes on?
If so, press 1, and the specific trouble will come up.
The lights then have the following meanings:
1 - low battery
2 - Bell circuit trouble
3 - System trouble. Power supply, output module or printer failure
4 - Tamper
5 - Communication failure (on the keybus circuit)
Hope this helps.
D7
Regards
rgj
31267[/snapback]
I would say you have a trouble in one of the modules attached to the panel. DSC is a bit tricky to faultfind if the trouble is in the module and you are without programming software. Anyhow, reading the event buffer usually tell's you exactly where the fault is.
I guess you have LCD - keypad if you have radio/intercom module. You can get to eventbuffer by *6 [MASTER CODE] and then search with < > arrows for Event Buffer and push * . You can scroll timestanps with arrows and with * you get proper info.
DSC rarely have any REAL faults in it. One of the most robust panels I have seen.
