inglishg Posted February 10, 2019 Posted February 10, 2019 I don't often get involved with CCTV, but have been asked fire help with a guys newly installed system. It's a Sannce DVR with two analogue 1080p HIK vision cameras. The cables are pre- made (two different "makes"), and the cameras and DVR have separate power supplies. The cables run through the house wall and then in different directions to the two cameras. There is minimal excess cable coiled up and they don't run next to power supplies. Both images are show interference - the colours are distorted. Is there something obvious? Cheers Quote
al-yeti Posted February 10, 2019 Posted February 10, 2019 26 minutes ago, inglishg said: I don't often get involved with CCTV, but have been asked fire help with a guys newly installed system. It's a Sannce DVR with two analogue 1080p HIK vision cameras. The cables are pre- made (two different "makes"), and the cameras and DVR have separate power supplies. The cables run through the house wall and then in different directions to the two cameras. There is minimal excess cable coiled up and they don't run next to power supplies. Both images are show interference - the colours are distorted. Is there something obvious? Cheers All junk equipment ? Otherwise could be the PSU for the cameras Quote
inglishg Posted February 10, 2019 Author Posted February 10, 2019 I don't often get involved with CCTV, but have been asked fire help with a guys newly installed system. It's a Sannce DVR with two analogue 1080p HIK vision cameras. The cables are pre- made (two different "makes"), and the cameras and DVR have separate power supplies. The cables run through the house wall and then in different directions to the two cameras. There is minimal excess cable coiled up and they don't run next to power supplies. Both images are show interference - the colours are distorted. Is there something obvious? Cheers 20190210125057.mp4 Quote
satsuma01 Posted February 10, 2019 Posted February 10, 2019 The image won't load properly but sounds the cables that are pre made are causing image loss someplace the video coax with a rg59 cable or a cat5 or 6 with a decent balun at each end of the run pre made cables are not much good from what I've found with them Quote "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
inglishg Posted February 10, 2019 Author Posted February 10, 2019 Thanks for the reply. Obviously my knowledge is inferior to yours, but a relative has a similar set up, and there's is crystal clear - same cameras and DVR. I presumed there's something interfering with the signal somewhere? I understood HIK vision cameras were ok? Cannot really respond about Sannce. Maybe I should suggest he changes his DVR? May prove if the issue is the cameras/cables or DVR itself... Cheers Quote
inglishg Posted February 10, 2019 Author Posted February 10, 2019 Thanks for the reply, much appreciated. Ok, I'll wire another camera into it, and see how the image is, before getting the ladders out... If I can prove a good image with a replacement cable, then it could be happy days :-) Perhaps I'll be sticking to my 30 years in security systems rather than poking my nose into the magic of CCTV! Thanks again for your help. Quote
al-yeti Posted February 10, 2019 Posted February 10, 2019 1 hour ago, inglishg said: Thanks for the reply. Obviously my knowledge is inferior to yours, but a relative has a similar set up, and there's is crystal clear - same cameras and DVR. I presumed there's something interfering with the signal somewhere? I understood HIK vision cameras were ok? Cannot really respond about Sannce. Maybe I should suggest he changes his DVR? May prove if the issue is the cameras/cables or DVR itself... Cheers Not that inferior lol But you could take a cat5 to the camera for the video with some baluns to see if it makes a difference if it doesn't might be PSU issue or something else Quote
james.wilson Posted February 10, 2019 Posted February 10, 2019 or fake gear? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
satsuma01 Posted February 10, 2019 Posted February 10, 2019 I'd say try a new cable first on cat 5 with Balinese and power run through that also whole the camera is powered check the voltage at the camera end it should be around 13 ISH volts if DC 12 adaptor Quote "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
