RevolvingSteve Posted February 19, 2019 Posted February 19, 2019 Some free time again so back onto the Alarm. I seem to have everything working on the main panel now and have been setting the alarm for a week or so, no issue! Now I want to add the RIO expander to put the extra door contacts in. I have fitted it and wired the RIO back to the Lfex on the same terminals as the KeyPad, I have a flashing green light on the RIO now, but cannot see anything that it has recognised the RIO or any extra zones in the zones menu? Any ideas? Quote
al-yeti Posted February 19, 2019 Posted February 19, 2019 List zones showing in menu When you added the Rio did you address it enter engineer mode then exit , I assume adding a Rio hasn't changed on the flex then when exiting it says new mod added Quote
GalaxyGuy Posted February 19, 2019 Posted February 19, 2019 Which firmware version flex? I seem to remember some issues trying to mix fx20 with portal and RIO. Never had the problem on fx50 or fx100. Quote
RevolvingSteve Posted February 20, 2019 Author Posted February 20, 2019 12 hours ago, al-yeti said: List zones showing in menu When you added the Rio did you address it enter engineer mode then exit , I assume adding a Rio hasn't changed on the flex then when exiting it says new mod added Yep, I didn't the enter/exit Eng mode, didn't show anything new (was 12, now 12.. I think from memory) Quote
RevolvingSteve Posted February 24, 2019 Author Posted February 24, 2019 On 20/02/2019 at 13:08, al-yeti said: Did you address correctly I have the addresses set as follows: KeyProx 1 : 0 KeyProx 2 : 1 RF Module : 5 (no idea why I set it to 5?) RIO Unit : 3 As always, thanks for the time and help. Quote
Nova-Security Posted February 24, 2019 Posted February 24, 2019 Not sure on the flex but 12 zones on the panel ? add an RF module doesn't that take 8 up making 20 and your panel is a flex 20 Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
RevolvingSteve Posted February 24, 2019 Author Posted February 24, 2019 1 minute ago, Nova-Security said: Not sure on the flex but 12 zones on the panel ? add an RF module doesn't that take 8 up making 20 and your panel is a flex 20 I thought the RF Zones were not included in the '20'? But I'm not 100% Quote
Nova-Security Posted February 24, 2019 Posted February 24, 2019 so what are you RF zones numbers 1021 to 1028 ? Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
