james.wilson Posted March 4, 2019 Posted March 4, 2019 1 hour ago, CARETAKER46 said: Hi Sorry to bother you again Guys, I have purchased the below from Ebay for £44.00, as he was moving house and he used it on 18Volt transformer. On the installation it is saying 24Volt, but I am not sure the Amp, as I will be operating the Video Door Bell and the Ding Dong Chime. How many Amps do I need for the Transformer is it 1amp or 2 amp, as I will need 24Volt. I will need to know the cable length, as I will need minimum of 2 metres, as my 240V socket is just behind the front Door. Power supply 16 VAC to 24 VAC Power Frequency 50hz to 60 hz. Power Consumtion 0.6A Power Consumtion 12W Your help will be Appreciated. https://www.hikvision.com/europe/Products/Video-Intercom/Wi-Fi-Door-Bell/DS-KB6003-WIP https://www.dynamic-cctv.com/media/attachment/file/d/s/ds-kb6003-wip-spec.pdf https://www.ebay.co.uk/itm/AC-DC-Mains-Power-Adaptor-Supply-Charger-PSU-800MA-1-0-AMP-24-Volt-Regulated-24v/332336065759?_trksid=p2485497.m4902.l9144 https://www.ebay.co.uk/itm/AC-DC-5V-12V-24V-1A-2A-3A-4A-5A-8A-Power-Supply-Adapter-Transformer-Charger-Plug/401560496857?_trksid=p2485497.m4902.l9144 https://www.ebay.co.uk/itm/SUMVISION-UNIVERSAL-POWER-SUPPLY-UNIT-15-VOLTS-24-VOLTS/113671698896?_trksid=p2485497.m4902.l9144 https://www.ebay.co.uk/itm/UK-Plug-DC-24V-1A-AC-Adapter-Charger-Power-Supply-for-LED-Strip-Light/202577851272?_trksid=p2485497.m4902.l9144 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
CARETAKER46 Posted March 5, 2019 Author Posted March 5, 2019 Hi James, Did you leave a blank message, as I could not see a message on your last post. Quote
james.wilson Posted March 5, 2019 Posted March 5, 2019 i highlighted the power req in red Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
CARETAKER46 Posted March 5, 2019 Author Posted March 5, 2019 Thanks James, Sorry never noticed, must be aged thing. What size transformer I will require, I know Hikvison said 24Volt and we have now found out the Amp is 0.6Aamp and I also want to connect to Ding Dong Chime and when I phoned Byron Technical, they said they usually state 8Volt 1Amp. Technical said if you used 24volt it will just burn the chime or it may keep buzzing. I need to use 24Volt to work or do I need a transformer , where it regulates Amp by it self. Byron told me as soon as you press the Door bell ring button, this is when the power will be applied. So this is why I was asking you guys which transformer I need to buy, as the guy who I bought it from he used 18volts transformer, but I don't he had his Ding Dong chime connected. So I need to buy the correct Amp rating or if I buy higher it may burn the circuit. Thanks Again. Quote
al-yeti Posted March 5, 2019 Posted March 5, 2019 3 minutes ago, CARETAKER46 said: Thanks James, Sorry never noticed, must be aged thing. What size transformer I will require, I know Hikvison said 24Volt and we have now found out the Amp is 0.6Aamp and I also want to connect to Ding Dong Chime and when I phoned Byron Technical, they said they usually state 8Volt 1Amp. Technical said if you used 24volt it will just burn the chime or it may keep buzzing. I need to use 24Volt to work or do I need a transformer , where it regulates Amp by it self. Byron told me as soon as you press the Door bell ring button, this is when the power will be applied. So this is why I was asking you guys which transformer I need to buy, as the guy who I bought it from he used 18volts transformer, but I don't he had his Ding Dong chime connected. So I need to buy the correct Amp rating or if I buy higher it may burn the circuit. Thanks Again. 8v 1A is the normal rating for a single mains operated door chime in a transformer , or if your using two door chimes then you need a 2amp version Quote
CARETAKER46 Posted March 5, 2019 Author Posted March 5, 2019 Hi Alyeti, Thank you for your reply. I am only using the existing Ding Dong chime, which was currently on the 8-12Volt Tranformer 1 amp. however I am now replacing the Door bell push ring to Video Door bell, which this New Video Door bell needs 24Volt and the Amp of the this new Video Door bell is 0.6Amp. I am only having 1 chime only, but due to New Video Door bell I have to replace the transformer to 24 Volt and I was not sure to which Amp to get transformer 1.5Amp or 2.0Amp or 3.0Amp on a 24 Volt Transformer, as it say 24 Volt on the Hikvision Video Door Bell. Chime on it own only needs 8-12 Volt and 1Amp transformer. Quote
james.wilson Posted March 5, 2019 Posted March 5, 2019 youu can use a 10A 8v transformer on your door bell but not a 1a 24v. they are 2 different voltages so you will need 2 supplies. one for your bell one for your other unit or a transformer from 24v ac to 8v fed from the 24v one Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
CARETAKER46 Posted March 5, 2019 Author Posted March 5, 2019 On 04/03/2019 at 16:26, james.wilson said: Oh right , as Hikvision said this model , which I purchased can be connected to your existing door chime, so this is why I was under the impression I can use one transformer for my existing chime and also WiFi video door bell to connect on my phone. if I keep 2 door bell, then there is this possibility the visitor or parcel guy might not use the one of the door bell, so this is the reason I wanted to keep only 1 door bell, which is the WiFi Video Door bell. Is this typing error 10A or should it be 1A 8Volt. i will see if there is a transformer 24V ac to 8V and will there be Amp rating on this transformer? Quote
james.wilson Posted March 6, 2019 Posted March 6, 2019 no its not an error the current demand is one thing that can be over, the volts cant be Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
CARETAKER46 Posted March 6, 2019 Author Posted March 6, 2019 9 hours ago, james.wilson said: no its not an error the current demand is one thing that can be over, the volts cant be Thanks James Learning new thing everyday. I will check if I can find a suitable transformer. Quote
