james.wilson Posted June 18, 2019 Posted June 18, 2019 why not use a hdmi to dvb modulator. A decent hdmi extender will work but im struggling to find a v2.1 on at 15m for my own house or even a 2.1 cable I have heard of some success using fire sticks and the recorder android apps but never tried it. I use mythtv and zm fed from a sw ahd dvr over rtsp Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
CARETAKER46 Posted June 19, 2019 Author Posted June 19, 2019 Hi James, This I have never heard of hdmi to dvb modulator, so I will have to google search and find out how it works and what cables i need to have, as I have already pull the cat5e , so I will just have to see what I can do with this at the moment. I will have to find out about the fire sticks and the recorder android apps, as my Tv is about 5 years old and it may not have some of the apps, as my Samsung tv had youtube and now it has been removed and was told I need to buy another TV , as this is getting out of date, typical and making spend more to buy another Tv. Quote
al-yeti Posted June 19, 2019 Posted June 19, 2019 20 hours ago, CARETAKER46 said: Hi Guys, would this work for my Hikvision Nvr to my tv to see the cctv. My NVR is in the front room and my tv is in other room and the cat5e cable length is 20-25mtr. I purchased the cat5e hdmi converter and it did not work, as it was without 12volt , it was from ebay. https://www.ebay.co.uk/itm/HDMI-Over-RJ45-CAT6-CAT5e-Cable-LAN-Ethernet-Extender-Repeater-3D-up-to-30M/183418433543?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D4ca1a9c7560044d2bf53e32c58332fdb%26pid%3D100675%26rk%3D2%26rkt%3D15%26mehot%3Dag%26sd%3D123086455878%26itm%3D183418433543&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3A8a56a63a-91ea-11e9-8e63-74dbd180ed12|parentrq%3A6b88293616b0abc5a120a95cffc922e6|iid%3A1 I also need to connect to my other tv in my next door house , so my mum can see the cctv on her tv. This is about 30-35mtr. So the question is would this work on both Tv. I have cat5e cable all pulled from Nvr to the both tv, as I just need cat5e to hdmi convertor to connect to both TVs, by using the cat5e cable for signal and then 1 Transmitter on the Nvr and the receiver I don’t know how many reciever I need, as one tv is in my next room and the other tv is in my mum house which is next door or you can just think it is in another room. The reason I am asking you these questions, so I don’t want to end buying the wrong item. Many thanks if you can help and advice buying the correct product/item. https://www.ebay.co.uk/itm/123086455878?ul_ref=https%253A%252F%252Frover.ebay.com%252Frover%252F0%252F0%252F0%253Fmpre%253Dhttps%25253A%25252F%25252Fwww.ebay.co.uk%25252Fulk%25252Fitm%25252F123086455878%2526rvr_id%253D0%2526rvr_ts%253D69bd86ef16b0aa67b6d08df5fff0e4df&ul_noapp=true This can work Quote
CARETAKER46 Posted June 19, 2019 Author Posted June 19, 2019 Hi Alyeti, So this will work the below link from eBay. https://www.ebay.co.uk/itm/123086455878?ul_ref=https%253A%252F%252Frover.ebay.com%252Frover%252F0%252F0%252F0%253Fmpre%253Dhttps%25253A%25252F%25252Fwww.ebay.co.uk%25252Fulk%25252Fitm%25252F123086455878%2526rvr_id%253D0%2526rvr_ts%253D69bd86ef16b0aa67b6d08df5fff0e4df&ul_noapp=true Quote
CARETAKER46 Posted June 19, 2019 Author Posted June 19, 2019 Hi Alyeti, I just noticed , as I have pulled the cat5e from the Recorder to 1st tv and another Cat5e and from the recorder to another TV and I will need to buy 1 transmitter and 2 receiver, as the tv is in different Rooms. Plus the Cat5e will get the signal to RX receiver from TX transmitter. My Recorder is in the front room, My 1st TV is another Room back of the house and 2nd Tv in another room, So how do I go about having the TX and RX, as I will need to 2RX one on each tv due TV's is both different room and the recorder is another room, so 3 different locations. I got the image from the ebay, this how they have set up, but my Hikvison Nvr Recorder where it is, there is NO TV in this room, just my Monitor. The below image shows the TV , Blue -ray Player and the TX and other picture shows the RX and TV. Quote
al-yeti Posted June 19, 2019 Posted June 19, 2019 1 hour ago, CARETAKER46 said: Hi Alyeti, I just noticed , as I have pulled the cat5e from the Recorder to 1st tv and another Cat5e and from the recorder to another TV and I will need to buy 1 transmitter and 2 receiver, as the tv is in different Rooms. Plus the Cat5e will get the signal to RX receiver from TX transmitter. My Recorder is in the front room, My 1st TV is another Room back of the house and 2nd Tv in another room, So how do I go about having the TX and RX, as I will need to 2RX one on each tv due TV's is both different room and the recorder is another room, so 3 different locations. I got the image from the ebay, this how they have set up, but my Hikvison Nvr Recorder where it is, there is NO TV in this room, just my Monitor. The below image shows the TV , Blue -ray Player and the TX and other picture shows the RX and TV. Only problem you might get is the resolution may keep trying to switch u til it finds a compatible one but you have switch to make it stick to source output Quote
