I have a problem. This system was working fine then suddenly started to beep regularly. The lights were flashing and when I tried to set the alarm this message came up"restore required. Code G16258 anti -code needed"   it also said control panel battery fault. What does this mean or do I need to get a professional in?
Sounds like you have had an activation and it's generated the need for a managed reset.
Put a photo up and someone will confirm
So your alarm has an sd1 connected to it , and alarm has an anticode displayed and wants a new battery???
I would suggest you try to contact the company that installed the system. If the system isn't under maintenance then it would be a good idea to get it looked at anyway if it hasn't been serviced in a while.
The system sound like it has been activated and if your not sure why then it would be a good idea to get it looked at as above.
SD1 is a dialler not the main system keypad.
