wattcom Posted March 25, 2019 Share Posted March 25, 2019 Just removed GSM module and replaced it with DigiWifi when setting alarm getting ARC call Fail error which anyone no where to turn that feature off on a Euro v10 Panel Never used ARC with GSM module so not sure why if thinks its on Quote Link to comment Share on other sites More sharing options...
james.wilson Posted March 25, 2019 Share Posted March 25, 2019 are there any primary numbers and acct info programmed in? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
wattcom Posted March 25, 2019 Author Share Posted March 25, 2019 I looked and I did remove all numbers that where used when GSM module was installed I used the C key to blank out number is that Righ thing to do? Isn't here a better way to clear that part of then programming ? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted March 25, 2019 Share Posted March 25, 2019 i haven't used a euro for over 10 years so will need someone else to chime in Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
grantc Posted March 25, 2019 Share Posted March 25, 2019 Switch Comms format to not used. You using Digi WiFi for app only? Go through WiFi settings within Comms to connect to router etc Quote Link to comment Share on other sites More sharing options...
wattcom Posted March 25, 2019 Author Share Posted March 25, 2019 Yep Digi wifi for App only App is all up and running and I can see the panel set and unset just keep getting that error Quote Link to comment Share on other sites More sharing options...
wattcom Posted March 25, 2019 Author Share Posted March 25, 2019 1 hour ago, wattcom said: Yep Digi wifi for App only App is all up and running and I can see the panel set and unset just keep getting that error Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 25, 2019 Share Posted March 25, 2019 21 minutes ago, wattcom said: Put the format back Put GSM back Restart Then switch format off Power down Remove GSM card I think it's a glitch Quote Link to comment Share on other sites More sharing options...
