Hi
I was hoping someone might be able to shed some light on a problem I have just encountered.
3 years ago I did a DIY installation of a 9571 with wireless expander and 1 remote keypad with tag reader.
Everything was fine until a week ago, when the keypad stopped responding to key presses ( I still got a confirmation beep with each press)
The screen alternates between.
9571    V5.00
Checking  Bus
and the date and time
01/01/2005            00.00
the time clock would begin counting, but it rarely got to 10 seconds before it again showed
9571    V5.00
Checking  Bus
these 2 screens alternated constantly for 2 days, before permanently showing
9571    V5.00
Checking  Bus
I foolishly thought it might be the keypad and I bought a replacement but whatever the problem is it isn’t the keypad as the new keypad display
shows the same message.
does anybody have any ideas ?
52 minutes ago, Galwayboy said:
Hi
9571    V5.00
Checking  Bus
01/01/2005            00.00
9571    V5.00
Checking  Bus
9571    V5.00
Checking  Bus
Cable fault ? Or panel fault , have you tried disconnecting both keypads put the new keypad on the panel on short cable to see if it works ?
Thanks, I haven’t tried that, but I will.
That is why I decided to enlist some superior diagnostic brains !
There are a couple of other clues to this puzzle
removing the keypad & main box cover did not trigger a tamper alarm.
 I did trigger an alarm by disconnecting the backup battery.
  • 1 month later...
Thanks but I got it sorted. All voltages were good, so took a gamble on it being a PCB problem.
 I got a 2nd hand PCB & case and luckily I was right.
Just 1 little question -  my proximity tags no longer work. Does the main alarm have to be specific to the proximity tag feature ?
It may just be that the alarm was for sale because that feature stopped working !
You need to programme them
The system will not let me program the tags.
 I follow the instructions, the last thing is to present the tag to the keypad, l get a double peep but the tag isn’t programmed.
 I’ve even bought new tags and tried the original keypad, which turned out to be OK but to no avail
So the option appears in the menu?
How much you pay for the second hand pxb and from where?
