what is everyone using for fastening cables up with to meet with the new 18th edition changes? I've just quoted a job that has to be mostly surface trunked, so steel cable ties are out. I have just found some clips that go in the trunking, D line clips they're called. Has anyone used these before, and how much of a faff are they?
No know jack about them , everyone here has used them plenty
But fastening cables depends on where and how , I still see steel cables above voids , metal trunking in communial walk ways or plastic with d clips or other fixings
I like the idea of the nailer, think that's going to have to be a definite investment.  I take it it can be used to fire nails in for the D clips as well, the pirelli's look good for fire cable, I'm thinking more along the lines of fixing alarm/Beldon/data cable.
  • 4 months later...
On 18/04/2019 at 10:09, james.wilson said:
Yes but becareful of the predrilled hole size of the dclip. Also can use plclips without predrilled holes when hidden. I was also meaning for other cable types
Most of the clips are plastic however
I think the 800 replaced the above
I purchased the 700e a few years back for a job, unfortunately never got round to using it. Pulled it out to use on a job and the batteries have leaked that's just my luck. I know that you can purchase replacement ones from flee bay has anyone ever brought any of these?
Regards TS
Regards TS
Are you being serious , you let the batteries leak inside it?
I assume it's cheap rubbish anyway so doesn't matter???
No, the batteries were in the case, this is why I was surprised!
Sorry should have been more clear.
Regards TS
Regards TS
Doh , Chinese batteries leaked all over the gaff?
I know even some of the branded ones do but not that severely
Sadly these were the original ones, yet to have a look on flee bay for replacement's.
Regards TS
