Al H Posted April 26, 2019 Posted April 26, 2019 Good morning everyone. First post and I’m hoping someone can recommend the best way to deal with my problem. Our house was prewired in preparation for an alarm installation. All the cables are in place around the house and just need the key pads, sounder, pirs wiring in. However the problem is that the cables terminating back to the control box site have been cut way too short. The cables will not put through any further and the flooring above is not accessible in any shape or form (wet room). I don’t want a wireless system. I’m planning on fitting a Texecom Premier Elite 24 (either Polycarbonate or metal). Any suggestions on the best, neatest way to extend the cables? The control panel will be fitted immediately to the left of the cables at the same height. See image. THANK YOU Quote
al-yeti Posted April 26, 2019 Posted April 26, 2019 16 minutes ago, Al H said: Good morning everyone. First post and I’m hoping someone can recommend the best way to deal with my problem. Our house was prewired in preparation for an alarm installation. All the cables are in place around the house and just need the key pads, sounder, pirs wiring in. However the problem is that the cables terminating back to the control box site have been cut way too short. The cables will not put through any further and the flooring above is not accessible in any shape or form (wet room). I don’t want a wireless system. I’m planning on fitting a Texecom Premier Elite 24 (either Polycarbonate or metal). Any suggestions on the best, neatest way to extend the cables? The control panel will be fitted immediately to the left of the cables at the same height. See image. THANK YOU Just join crimp , solder and extend cables etc You could bury them in wall and put a face plate on top after I would open the plaster up more towards ceiling and fit panel higher up if possible then joins can be inside panel Do you have a better picture? Quote
Al H Posted April 26, 2019 Author Posted April 26, 2019 Total length of wires to ceiling is about 28cm Quote
sixwheeledbeast Posted April 26, 2019 Posted April 26, 2019 I wouldn't extend them there is enough there for a Premier. Just open up the plaster and containment for what you need then mount the panel to cover the hole. Quote
Al H Posted April 26, 2019 Author Posted April 26, 2019 Thanks to you both. Really appreciate your support. Ill go ahead and order the Polycarbonate version unless you think different. Thanks again both Quote
al-yeti Posted April 26, 2019 Posted April 26, 2019 11 minutes ago, Al H said: Thanks to you both. Really appreciate your support. Ill go ahead and order the Polycarbonate version unless you think different. Thanks again both Thought steel version has more space Swb? Quote
MrHappy Posted April 26, 2019 Posted April 26, 2019 1 hour ago, al-yeti said: Thought steel version has more space Bad design, row or 20mm holes in the middle of the enclosure. I'd put a plastic expander on the short wires Quote Mr Veritas God
Al H Posted April 26, 2019 Author Posted April 26, 2019 Hi Mr Happy Thank you also. Please can you explain. Plastic Expander ? Thanks Quote
al-yeti Posted April 26, 2019 Posted April 26, 2019 22 minutes ago, MrHappy said: Bad design, row or 20mm holes in the middle of the enclosure. I'd put a plastic expander on the short wires Yes cable.management is more on hkc stuff aswell in my opinion Galaxy range and texecom have better space to lash it in Quote
