ElecTech Posted May 10, 2019 Posted May 10, 2019 What's the situation with Gent equipment, are installers required to be "approved integrators" to even make minor changes? I have an enquiry to replace a Gent call point due to minor damage, can this be done without approval? Quote
Ryan Clifton Posted September 3, 2019 Posted September 3, 2019 You can change a device as long as it’s like for like and also do so without stopping the loop, but you will have to be able to safe address if needed and potentially back it up. It is not advised to back up without a current download though. It can be a bit of a mine field but easy systems to use once you get used to them. If the choice of using a gent certified engineer is there I would say go for that to be safe. I’ve just seen the date on this but may still be relevant Quote
