Hello
i think the alarm panel or keypads have started developing a fault, whereby occasionally the max in exit keypad displays system in use when the exit code is set, have to wait 20-30 seconds for it to clear, never happens with the other keypad, but thismonly used for part setting.
so wish to keep all wired PIR and smokes for contacts, but replace the panel, two keypads and two external sounders...
here is a list of of what I have, wonder if there are obvious best choices for replacing panel sounders and keypads, thanks
1- front door contact
2- kitchen PIR
3- Lounge room PIR
4- Game room PIR
5- Garage door contact
6- Garage internal contact
7- store room PIR
8- Master bed PIR
9- 3rd bed PIR
10- 2nd bed PIR
11- Landing PIR
12- Hall smoke
13- Game room smoke
14- Lounge & Master bed smoke
15- Bedrooms 2 & 3 smoke
16- Landing & store room smoke
17- Garage control panel
18- Hall & landing keypads
19- Landing sounder
20- front & rear sounders
To be honest a panel for that size system would be a Professional panel & would be better being Installed, Programmed and tested by a skilled alarm engineer. It really isn't in any way a DIY job.
You would be best contacting a couple of good local installers for prices.
Don’t plan on a self install, wanted to be given some ideas on controls panel , kepypads sounder etc
thanks
Can’t see any way of editing my post, but I purposely didn’t put this in DIY, for the simple reason I don’t intend doing it myself, just wanted some equipment advice.
Have decided to do away with all the smoke alarms, as I a, told they only last 7 years and most are now over 16 years old....will replace with 3 or 4 standalone smoke alarms.  Also am told by an enquiry I made that
A Pyronix  Euro 46 8 zone control panel., a euro zem8 8 zone wired expander  & two Pyronix Euro keypads, & a  Pyronix delta bell.
been also told that to have TWO external sounders would require an extra PSU, whereas my gardtec 840 see,S t accept two easily., so wonder wh I can’t have two, a PSU shouldn’t be too expensive should it?
not clear if this is my cheapest option to replace the specified components I.e. two kepypads alarm panel and an external alarm, all PIRs and door contacts to remain.
One other enquiry suggested a scantronic  hybrid panel, which as. I Understand has Wi-fi included and some wireless capability also, not sure yet if this requires extra modules or not, or if the Pyronix is my best choice
thanks
Sorry mate, but if you don't plan on doing it yourself then why are you asking about panels etc ?
Each Installer will have their own preferred brand of panels and will happily tell you what is needed for the job, you'll rarely find an installer that will fit customer specified panels. I certainly wouldn't.
As I already said, contact some local installers and discuss with them.
Posted (edited)
Seriously, I can’t believe why you are so unwilling to help me, if you have nothing to suggest, then with respect why are you replying to my  post ?
lets say installer 1 says alarm system A are the best ever,
then installer 2 says alarm system B are the best, then installer 3 says alarm system C is the best ever, they ALl have their reasons.
as a homeowner I have to simply guess which is the best, so my idea, as daft as you think it is, was to ask people ‘ in the know ‘ which is the best route and if one of my installers selects that, then end of problem, if no one does I can ask them to compare their choice with the forum recommendation......seemed a good plan.....guess without any further replies I will have to research elsewhere, just wonder the point of a forum that won’t offer advice....
Edited by Reddwarf4ever
  • Downvote 1
Moderator
maybe this should be moved to your DIY section, as I am looking for guidance, even if I don’t install myself
Posted (edited)
I didn't say I was unwilling to help, I gave you advice "Call a local Installer" you seem to miss the point.
Your asking for advice on what panel is best, because local installers will give you different advice.
So will we, we all have our preferred equipment. Whether that be Honeywell, Pyronix, Texecom etc. So your really in the same boat.
If you ask most professional installers to compare what they specified with what someone on a forum has suggested, they'll walk out the door.
Edited by Specialist
20 minutes ago, james.wilson said:
It's not as simple as that.
Think of the question, what's the best car?
To extend, any panel pretty much will do work with your sensors. But if you wanted to know a recommendation as to the easiest to use panel that can also do xy and z etc etc
