Tonybeemer Posted April 10, 2019 Posted April 10, 2019 Hi every one, I've just purchased a new Texecom Ricochet 64 Way. Set up the system 3 PIR and 1 door contact no problem apart from I realised that when setting up the config it turns of the zones on the hard wired panel so I re instated them in the config/programme menu as I wanted to add two additional hard wired PIR and looped out the other two. But unless these zones are set as not used I get tamper showing? Any Ideas please? Thanks. Quote
james.wilson Posted April 10, 2019 Posted April 10, 2019 Did you link out with cable or the relevant resistor? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Tonybeemer Posted April 10, 2019 Author Posted April 10, 2019 High James. Normally the Veritas panels come with a little bag of resistor but on this occasion not. So I just linked out with cable is this my problem? Thanks. Quote
james.wilson Posted April 10, 2019 Posted April 10, 2019 Don't know the panel you may be able to program them as double pole Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Tonybeemer Posted April 10, 2019 Author Posted April 10, 2019 Hi James, possible. Just a bit strange as I've seen someone on YouTube having the same problem but for them it was a easy fix as they were using all wireless PIR so just set the wired on board zones to not in use? Thanks. Quote
sixwheeledbeast Posted April 10, 2019 Posted April 10, 2019 Don't link them out, program them out. You should get resistors with the kits and they are DEOL default normally. Quote
Specialist Posted April 11, 2019 Posted April 11, 2019 Welcome. Speak to your supplier about the missing parts, they should hopefully give you replacements. Quote Customers Love us, Intruders Hate us.
al-yeti Posted April 11, 2019 Posted April 11, 2019 On 10/04/2019 at 15:14, Tonybeemer said: Hi every one, I've just purchased a new Texecom Ricochet 64 Way. Set up the system 3 PIR and 1 door contact no problem apart from I realised that when setting up the config it turns of the zones on the hard wired panel so I re instated them in the config/programme menu as I wanted to add two additional hard wired PIR and looped out the other two. But unless these zones are set as not used I get tamper showing? Any Ideas please? Thanks. Expand Where you panel? eBay? amazon? Think they have returns policy if bits were missing , maybe it was used panel , although resistors are cheap and programming them out is easier Quote
Tonybeemer Posted June 3, 2019 Author Posted June 3, 2019 Hi every one, I've just purchased a new Texecom Ricochet 64 Way. Set up the system 3 PIR and 1 door contact no problem apart from I realised that when setting up the config it turns of the zones on the hard wired panel so I re instated them in the config/programme menu as I wanted to add two additional hard wired PIR and looped out the other two. But unless these zones are set as not used I get tamper showing? Any Ideas please? Thanks. Quote
Specialist Posted June 3, 2019 Posted June 3, 2019 Hi: Isn't this the exact same question you asked on April 10th ? 1 Quote Customers Love us, Intruders Hate us.
